#29 |
...and ZL1 1LE were all manual prior to half way through the 2019 MY.
My buddy just had the key think happen to his 2022 GMC ATX. Watched it all go down on his ring camera. Took them less than a minute to drive off. |
#30 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I was just reading a ram forum this morning about this unit, on the website They recommend starter relay for automatic transmission and fuel pump relay for manual transmission
#31 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Exactly. This is also explained on their website.
Mosaic black 2018 Camaro 2SS A8 (sold) |
#32 |
![]() Drives: 2024 ZL1 Join Date: Apr 2023
Without having to look it up does anyone know which relay/fuse is for the fuel pump and/or starter?
#33 |
I would prefer you pop your hood and look under your fuse box lid and take as many pictures on the way to doing that, so we can see your new beautiful car! Fuel pump relay is in the trunk and I think the starter relay is in the front
#34 | |
#35 | |
![]() I have a mild to wild on order and if it works I will report back either way, if it doesn’t work I will go for the other relay thingamajig |
#36 |
![]() ![]() ![]() Drives: '23 LT1 A10 Join Date: Oct 2015
What is mild to wild, have website link?
24 LT1 M6 Sharkskin Metallic
14 Mazda Mazda3 S Grand Touring (Daily) |
#37 |
The exact parts can be purchased on Amazon for less than 20 bucks. I would have to do some searching again to find them and will post back if I do.
https://www.camaro5.com/forums/showthread.php?t=220686 or a DIY version... https://www.camaro5.com/forums/showthread.php?t=226858 ![]() |
#38 | |
![]() While I'm posting fuse box pictures... I went a bit overboard with installing the plaque. I had them do a reverse radius on the corners and cleco'd it together then installed with 3213 - 4 - 5 Cherrymax rivets. If they will hold an F18 together at Mach 2 they should be enough to hold the plaque on the cover... ![]() ![]() ![]() |
#39 |
Looks good, no way that’s falling off!
#40 |
![]() Drives: Red 2018 Chevy 1LT RS Package Join Date: Sep 2014
That is insane. Thanks for the heads up
