Old 08-25-2023, 08:52 PM   #29
clg82
Drives: 2020 Camaro ZL1
The color and unmachined surfaces are really different. The 1740 was surprisingly heavy, too. BUT - I'm no expert, and didn't remember to weigh either the last time I had the 2650 off, so... I bet you're right though. I forgot to mention the THPSI billet lid, too, which drops a tiny bit of weight. It probably makes up for anything his PI system adds.
Radz, he did inquire about the CARB process as well, any update on that for us Cali folks. OP I got in riiiiiiight before they pulled the CARB back so I was able to get it shipped and installed at a shop here. But I'm not sure what the status of the CARB cert is....
Old 08-26-2023, 11:04 AM   #30
Camfab
Drives: ‘23 ZL1-1LE
So wait, clear this up for me. They had a CARB number and lost it?
Camfab is offline   Reply With Quote
Old 08-26-2023, 01:12 PM   #31
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Too much fun for the stock gaskets/hardware to handle, I guess. He made a good call on throwing the 2650 on there. I mean, while you have it off...
The torque to yield process on the stock head bolts wasn’t done right or it just flat out stretched the factory bolts. Has been fine now with ARP head bolts using the same .028 gaskets. My C7Z is running 11:1 compression with 19-20psi and hasn’t had a hiccup with ARP head studs. Same tuner for both
CamOnlyJabroni is offline   Reply With Quote
Old 08-27-2023, 12:18 AM   #32
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Don't feel bad about what may have happened bro. These OE bolts are weird despite how stout they appear. During my initial torquing on my build one of the bolts broke deep down inside the engine block for no particular reason. It really made the extraction process difficult at the time, but luckily the block was saved without needing to do anything special to the threads in place, and nothing was damaged except for needing the obvious replacement bolt. I even noticed during the build that the FSM indicated to install the bolts dry when that goes against all traditional modern aluminum engine build wisdom, but I obliged as I thought maybe there was something special about this engine that wasn't being specified in the verbiage.
That is the second time GM has let me down while following their instructions to a T. Next time I'm doing something I have noted to myself that if I see something odd in their instructions that I'll go specifically out of my way to ignore it.
758 HP/ 804 TQ
Old 08-28-2023, 07:16 AM   #33
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
To another post: CARB-certification was never lost. It was never accepted by ARB.
clg82: They are still going back-and-forth with ARB. I should be receiving another update this week - fingers crossed...
'20 ZL1 Black "Fury"
Old 08-28-2023, 09:56 AM   #34
clg82
Thanks radz us Cali peeps appreciate it.
Old 07-05-2024, 07:23 AM   #35
LAPPEDbyZL1
Drives: 2018 Camaro zl1 1le
Has anyone weighed the stock blower and the 2650?
I am surprised it's only 20lbs like people have mentioned?
LAPPEDbyZL1 is offline   Reply With Quote
Old 08-25-2024, 08:37 PM   #36
Camfab
Drives: ‘23 ZL1-1LE
I believe the 20lbs was between the factory blower and the 2300, not the 2650. Probably closer to 40
Old 08-25-2024, 10:14 PM   #37
toohighpsi
Drives: 2015 C7 Z06 M7
I have both sitting on a shelf, I'll try to remember to weigh them tomorrow.
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
Old 08-26-2024, 05:25 AM   #38
Z OH 6
Drives: 2024 CT5-V Blackwing
Please do, this question comes up every so often and no one has the answer.
Old 08-26-2024, 06:55 AM   #39
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I never followed up in this thread, but Magnuson achieved CARB exemption (D-488-61 and 62) close to a year ago, so it's a go in CA. If you ordered before then, like me, you'll have to reach back out to Magnuson, with a picture of your engine bay showing compliance, and they'll send you a sticker.
Old 08-29-2024, 12:53 AM   #40
toohighpsi
OK, here we go. I tried my best to make sure they had the same components included in each weight although I just noticed that from the pictures that I left the throttle body bolts in the 1740, should only account for a couple ounces.
Name:  SC Weight-3.jpg
First the TVS 1740 - this is the tall lid tilted brick unit, its weight is 68lbs 2oz.
Name:  SC Weight-2.jpg
Next is the Maggie TVS 2650 - this is the original 3 piece housing, its weight is 84lbs 10oz.
I don't know if the newer once piece housing is lighter or heavier.
Name:  SC Weight-1.jpg
Finally, I had a THP lid laying there so with the that 2650 weight was 82lbs 15oz.
So in summary the TVS 2650 weights 16lbs 8oz more than the LT4 1740SC
Mike
www.toohighpsi.com
2021 Porsche GT4 M6
2023 Corvette Z51
Old 08-29-2024, 06:36 AM   #41
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Good stuff Mike, thanks for posting those weights up.
Old 08-29-2024, 06:47 AM   #42
Z OH 6
Attachment 1155438
Attachment 1155439
Attachment 1155440
Thanks, this confirms that I will make the move to a 2650 eventually. I wasn't sure if weighed 40lbs more but 16lbs is easily worth it.
