Old 06-16-2023, 03:30 PM   #29
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Originally Posted by Katech_Mike View Post
Thank tank comes out of 6th gen's fairly easily. Much easier than the engine that you just removed and reinstalled
Haha... I'm sure your right
Old 06-16-2023, 03:31 PM   #30
SOCAL.M6.ZLE
Will your solution be a drop in, or external pump?
Old 06-16-2023, 09:14 PM   #31
Efi69Cam
Drives: Camaro
Our set up will keep the bucket functioning 100% as the OEM intended as well as support higher low side fuel pressures.
There is nothing on the market currently that achieves both of those things.
It will be worth the wait.
Any plans for a similar product for a 2017 Yukon?
Efi69Cam is offline   Reply With Quote
Old 06-19-2023, 09:33 AM   #32
Katech_Mike
Drives: 2015 Camaro ZL1
Drop in. You will have to drop the tank. Which on a 6th Gen isn't difficult.
Katech_Mike is offline   Reply With Quote
Old 06-19-2023, 08:05 PM   #33
LloydK
Drives: 2020 SS Camaro A10
SMG Big Boy Fuel Pump
I have one in my bolt-on ZL1, no cam or lash cap, had plenty of room to run full E85, they work, put down a conservative 650 whp, cam and ported blower next ��
LloydK is offline   Reply With Quote
Old 06-23-2023, 11:41 AM   #34
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
So do you guys recommend the jms, fuel pump, or both to tune on e85?
Old 07-22-2023, 11:15 PM   #35
SOCAL.M6.ZLE
Awesome... how long have you been running it? any issues? Did you install yourself?
Old 07-23-2023, 01:55 AM   #36
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Lack of a fueling solution like this is the main reason I would not attempt to significantly modify my 2018 ZLE. You can add all the power mods you want, but without highly reliable fueling to support it under 1/2 tank and high G conditions on a road course, you're driving a ticking time-bomb. The BigBoy seems better than others, but according to Katech it doesn't provide the surge tank capabilities of the stock bucket because it loses its seal.
If you track your ZL1 you need this capability for high G turns or you will blow your motor due to dangerous lean AFR from fuel starvation. This is a must for anyone tracking their ZL1, and it looks like the Katech solution resolves this issue.
The best solution for track use is a fuel cell with high capacity racing pumps and a built in surge tank, but this requires you to go full race car and lose streetability.
SFV1LE is offline   Reply With Quote
Old 07-23-2023, 11:41 AM   #37
SOCAL.M6.ZLE
Sounds like a good time to poke Katech again on a ETA for their drop in solution?
Old 08-11-2023, 08:00 AM   #38
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Just wanted to update that a Friend of mine had this SMG pump installed on his 2016 SS.
Mods:
Rods/Pistons 377 (10.7:1)
Ported heads
BTR stage 2 centri cam with 38% lobe
LPE HPFP
+30 FIC injectors
P1x stage 2 with 8" lower 3.9 upper(12psi)
Based on the logs this setup is trying to make around 800-820whp.
On E50 this low side pump will not hold pressure above 6200rpm. It drops like a rock down into the 30's and rail pressure tanks. I tried SMG's suggested pump settings and everything in-between. If we turn the JMS voltage booster on, then the pump holds pressure perfectly, but this pump does not like the voltage booster. It causes the FSCM to throw insufficient fuel codes which never happened with the LT4 low side pump. The fact that the pump will hold commanded pressure with a JMS tells me that it simply isn't capable of keeping at normal drive voltage. So, it's not an issue with the FPR bypassing excess pressure.
Anybody out there that has made one of these work on a 800whp + build running E50+ I am all ears!!
Old 08-11-2023, 09:07 AM   #39
c0ncept
Drives: LS powered
Mods:
Ported heads
LPE HPFP
+30 FIC injectors
You found the reason no one making any real power runs that set up...
c0ncept is offline   Reply With Quote
Old 08-11-2023, 09:59 AM   #40
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
We will have information available by the end of next week.
Katech_Zach is offline   Reply With Quote
Old 08-11-2023, 10:06 AM   #41
KingLT1
KingLT1's Avatar
According to the website it's supposed to be able to feed "real power". This size pump feeds Hellcats making 900whp on E85 at much fatter AFR's. I don't think very many have run this pump because it hasn't been out very long for gen 5 LT stuff, nor has it been proven. But I appreciate all the help you have provided!!
Old 08-11-2023, 10:25 AM   #42
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
Reading the reviews they are saying you must follow their tuning setup for the pump. Did you check out the sample file? https://cdn.shopify.com/s/files/1/07...t?v=1684499180
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
