#29 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
#30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
I wish I would have grabbed a picture but forgot. It was not quite that bad. More like a thin level layer.
<Insert Cars You Own Here>
#31 |
![]() Drives: 2017 ZL1 Join Date: Aug 2020
Changed mine today and it looked like ur pic.
Thankfully some left over to put behind each ear and under the armpits prior to a hot date… |
#32 |
OMFG!!! I hope not, diff fluid is ****ing awful smelling.
#33 |
376 cubic inches of fun
As far as I can tell, 19352759 is NOT for an LS differential!
I would challenge the dealer's knowledge. |
#34 |
#35 |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
The E-Diff is not a limited slip in the traditional sense, the clutch packs are in the ATF control circuit and not the differential housing, using a LS oil will not cause any harm but it's not required. I use Mobil1 Delvac 75W-90 non LS in my 1LE to good effect, that and true synthetic gear oil doesn't stink. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#36 | |
#37 |
Thank you Al Oppenheiser!
#38 |
![]() ![]() Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
the world's best, organic weed killer
#39 |
Good point. That is a classic control loop problem, where the control loop response frequency and the mechanical stick-slip frequency overlap.
It can be fixed in two ways, or a combination of the two. That is, speed up or slow down the control loop response and/or modify the transition from sliding to static friction using friction modifier. I bet GM knows what the optimal solution is, but that doesn't mean they will implement it. I'm speaking from experience here, with touchy mechanisms and control loops. |
#40 |
Corre Caminos
Drives: '24 1SS 6M 1LE Join Date: Jun 2022
That's what I do as well. If it needs to be high enough, I just jack the car up and, using the blocks, build a tire cradle under each wheel.
'24 1SS 6M 1LE
