#29 |
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
He ignored 2 pcv valves.
You could make your own setup but do some digging beforehand. Like a lot. The setup he is using will only work when the engine is under boost. So will have no flow or reverse flow when the actual pcv valve that has manifold vacuum is working. ( idle and part throttle ) "normal driving" |
#30 | |
![]() Drives: 2021 camaro 1ls Join Date: Nov 2020
#31 |
I empty the catch can when I change the oil (it's the Mishimoto as well). It usually has about one ounce of oil each time.
