Old 06-23-2025, 12:14 PM   #29
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
2nd one, the RED ones are the 0 ohm wires I have and I them, I've never had an issue ! Get wire jackets/sleeves as well to go around them !!!! If I remember correctly, they are custom length or you need to indicate how long you need them to be. I will look back and see if I have my order details.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
2023_ZL1-AUTO is online now   Reply With Quote
Old 06-23-2025, 12:21 PM   #30
2023_ZL1-AUTO
Drives: 2023 ZL1
Yep, if I remember correctly, I just measured the stock wires and made sure the new ones were the same length. I'm not sure if this will be a requirement when you place your order or not.
I hope that helps!
Old 06-23-2025, 05:40 PM   #31
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
These are the ones I use:
https://granatellimotorsports.com/i-...?q=28-5362HTRB
Old 06-23-2025, 11:46 PM   #32
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
I vote for Granatellis as well. I have the zero ohm ones. They've never been a problem for me.
758 HP/ 804 TQ
