Old 10-04-2024, 12:11 PM   #29
Anom1LE
Anom1LE's Avatar
Drives: 18' 2SS 1LE, 94' Z28
Bump to warn those who haven't seen it yet
2018 Camaro 2SS 1LE - 1,xxxHP
D-1XH Procharged, LME 416, GPI/CID Track Attack Heads, BTR top end,
Katech oil pump, Pray Tuned, Stainless Works, Anderson Composites,
13GFab, BC Forged & More
1994 Camaro Z28 - 7xxHP
Nitrous Outlet Direct Port Nitrous & more, Creator of AggreSSive spoiler,
Multi Magazine Featured Camaro Z28 in GMHTP, Super Chevy,
Nitto, and Camaro Performers
Anom1LE is offline   Reply With Quote
Old 10-04-2024, 08:18 PM   #30
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Definitely a real thing and should be taken seriously, but I think I may just stick one or two water alarms down there instead of some phone app device.
speedyink1 is offline   Reply With Quote
Old 10-09-2024, 11:33 AM   #31
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
For a few dollars you can just put a battery-powered water sensor in the trunk well and it will start screaming when it gets wet. No need for fancy BT detectors, just a simple water sensor will do.
Daily Driver mileage update: 64k mi. @ Apr 2026
Old 10-09-2024, 11:44 AM   #32
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
if you are not in or the near the car when it starts screaming at you then it doesn't help.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 10-09-2024, 06:36 PM   #33
Whoomba
Originally Posted by ctrlz View Post
It's an idea.
The problem is water can come in pretty fast in heavy rain, and the hole needs to be sized to get that water out before it rises to the point it can cause damage. Also, holes can get partially obstructed by debris, and not drain quickly.
Not saying this won't work, just wondering how many people want a 3/4" hole in the trunk.
There’s a one valve with a gm port number for that. 39123504.
Old 10-17-2024, 08:28 PM   #34
Colin101234
Colin101234's Avatar
Drives: 2017 FIFTY 2SS HCI
I had an issue with water in my trunk (couple inches of water). Thankfully I noticed it before it caused an issue and GM cleaned it all out and put di electrical grease on everything. GM said they fixed it. But the other day I noticed it was damp in there. Do you think this plug actually fixes the issue? Now I'm concerned.
*STG 1.5 Frankenstein ported/milled heads(.025),
*Custom Cam Motion Cam (224,242[.647/.639])
1 7/8 headers, Ported LT 2 Manifold, Solar Ported 95mm TB, Cold Air Induction CAI, CHE Valve seats, Inconel EX valves, FED/PAC .700 dual springs, VVT Delete, CHE Trunnions, Caddy R Lifters, 3 In Midpipe, NPP Borla atak mufflers, GPI tune.
Colin101234 is offline   Reply With Quote
Old 10-18-2024, 10:19 AM   #35
ctrlz
How did water get in? Bad gasket?
I would put some towels in there and turn a garden hose on the trunk lid. see if it leaks.
Di-electric grease is fine, but I bet they only did the connections. Water that sits in the trunk eventually corrodes circuit boards and fuse box internals. I doubt they disassembled those and coated them. And di-electric grease is only indicated where you want things to be conductive. There are anti-corrosion gels which are not conductive.
Old 05-01-2025, 08:26 PM   #36
Colin101234
Sorry I never got back to you, I never found out where it comes from and honestly my solution has just been don't drive it in the rain. It only happened once badly after it sat at the dealership for days in a MASSIVE thunder storm that went for days. I have since decided to just put in the drain plug because I never found the source. But other then that idk what else to do.
Old 03-27-2026, 08:24 AM   #37
Anom1LE
Anom1LE's Avatar
Up to the top for those who are now starting to experience this.
Old 03-27-2026, 06:19 PM   #38
DC17ZL1
Drives: Metallic Black 2017 Camaro ZL1
There is a TSB for this - I don't remember the # - that involves the dealer drilling a "large" hole for drainage. I never experienced this in my 2017, but decided to buy a WeatherTech trunk liner which has a pretty high lip and looks like it would handle the situation. Mine is garage kept and I'm in AZ so rain is usually not an issue.
DC17ZL1 is offline   Reply With Quote
Old 03-27-2026, 09:03 PM   #39
Corky
Corky's Avatar
Drives: 2019 1SS M6
I decided to follow the TSB and install the plug a while ago...Seemed like the easiest solution...I have a small white paint mark on the lower corner of the back window and I've always wondered why GM had it there...Never had any water issues but the vehicle is always parked in the shop...
1st Gen ground effects kit GBA black | Mamo V3 ported TB | GM CAI | Velossa Ram Air | AWE touring axle back| Xpel PPF | illuminated door sills | Upgraded door panels with spectrum lighting |ZZP pillar pod with Banks Idash pro/AEM wideband
Corky is offline   Reply With Quote
Old 03-31-2026, 04:56 AM   #40
lynyrd
lynyrd's Avatar
Drives: Camaro 2.0 LT 2018
Send a message via Skype™ to lynyrd
I have this mat in my car, it hasn't changed anything, I still have water in the trunk.
2018 Camaro 2.0 LT Turbo, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights
lynyrd is offline   Reply With Quote
Old 03-31-2026, 05:00 AM   #41
lynyrd
lynyrd's Avatar
Did you place the plugs from underneath the trunk?
Old 03-31-2026, 06:21 AM   #42
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Why don't you just pull all the panels off the inside of the trunk, fold the seats down, and use a water hose to pour water over the trunk and roof, and figure out where the water is coming in.
