#29 |
![]() Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
For the high RPM will you convert the engine to dry sump? I was wondering if my LT1 could be converted to dry sump using OEM parts.
#30 | |
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
I think it would be more advantageous to go to a real dry sump such as a Dailey or ARE |
#31 |
Good Morning everyone, Hope everyone is enjoying their week.
The engine is going back in, everything is coming together nicely. A big part of this RPM target is keeping everything stable. To help do this, I increased rigidity in a number of places to prevent unwanted instability at full song. I am using Trend 7/16-.165 wall double tapered pushrods (shown in one of my last posts). Typically these do not fit a stock LT cylinder head, but paired with the johnson lifters I chose with offset cups, the pushrod is angled slightly different for additional pushrod clearance. I rolled over the engine slowly and checked every hole for clearance, and to my surprise no additional clearance had to be added. These are also a bit tricky to install, it is very easy to accidentally have these pushrods ride on the snap ring that retainers the lifter cup into the lifter. Each pushrod was carefully installed to avoid accidentally hanging a valve open. With the increased spring pressure and stiffness of the pushrods, I chose to use the comp cams BSR shaft mounted LT rocker arms. These utilize an OEM rocker arm body with their compound angle shaft system. This is an extremely nice piece, it utilized the lightweight nose of a stock rocker arm body with the rigidity of a shaft mount system. I was going to pair these with ARM LT rocker arm studs, but to my surprise there was not enough clearance in the comp cam setup for the ARP nut included with the kit. I am not worried though, the supplied grade 12.9 bolts will be just fine over the OEM bolts. I will be using out Katech oil pump for obvious reasons, I do not want to risk having a failure down the road. I will also be using our new VVT delete cover that utilizes a modified GM single bolt LS cam gear. I engineered this gear to be plug and play, it has the correct offset to match the OEM LT1/LT4 locked out timing without throwing off the fuel pump angle or cam timing mark positions. The build is coming together nicely, below are some more pictures ![]() Op1, Katech AFM Delete Cover ![]() Katech AFM Delete Cover, Finished ![]() Checking Pushrod Clearance / Pushrod installation ![]() Comp Cam BSR LT Rocker Arm ![]() Comp Cam BSR LT Rocker Arm, Torqued ![]() Katech Oil Pump + Katech VVT Delete Gear ![]() Katech VVT Delete Cover ![]() Katech Lightweight Aluminum Flywheel
#32 |
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I've been following this and love the idea. Thanks for sharing the details and pictures of the process.
#33 | |
Less driveline mass = faster acceleration from the engine |
#34 |
![]() Drives: Camaro 1ss Join Date: Nov 2019
So sick! loving this build
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
#35 |
Hope everyone had a good holiday! I have some more progress being made, the engine is installed and we are on the home stretch at this point. There isn't too much left to do other than final button up and some fab work. In my next post, I'll put some more details on the catch can setup I designed, intake modifications for the 120mm throttlebody, and some of the small items that I will be doing for plumbing. For now, here are some install pictures of the engine + C&R Racing goodies that will keep this build living. Engine Going In ![]() Engine Installed ![]() C&R Bricks Installed ![]() TooHighPSI Lid Installed ![]() C&R Race 42mm Heat Exchanger ![]() C&R Race Oil Cooler
#36 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Looking GREAT Zach... when do you expect to fire her up?
Also... Can you explain the benefits of the lightweight flywheel for the LT4? Are the benefits just in reduced rotating mass and engine wear, or does this somehow benefit power delivery with the stock LT4 blower?
#37 | |
For me, my thought process is this: The 2650 rotorpack is quite a bit heavier than the 1740 LT4 rotorpack. By reducing the mass of the flywheel and the cam gear, maybe it offsets the additional weight of the heavier rotorpack. You would see an improvement in acceleration and deceleration with a stock blower when using a VVT delete gear, lightweight flywheel, or the combination of both |
#38 |
Weekend update! The car is alive and well. I will post some preliminary dyno numbers when they are available.
On Monday, I will also post the aux pump fuel system and injector choices for this build to support my fueling needs temporarily. In the winter, I will be switching to a true in-tank pump solution. For now, the aux pump will do it's job. |
#39 | |
![]() Drives: 2019 Camaro 2SS Join Date: Aug 2020
![]() By the way awesome it’s running!
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
#40 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Jun 2020
Hopefully I can see this when I come check mine out in a couple weeks. I think Mike said you were doing all the specifications on my Corvette build.
https://www.camaro6.com/forums/showthread.php?t=604945
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
#41 | |
Shadow Gray '19 ZLE M6
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#42 | |
Congrats Zach! Cant wait to hear this beast!!!
| Tags |
| katech, lt4, performance |
