Old 10-12-2023, 09:54 PM   #29
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Originally Posted by PostalLDMC View Post
Why run 93 in a V-6 when it's the 1 engine that can run on regular gas. The higher the number the slower it burns, which is only more carbon build up. That's why some many run E-85. I may be wrong but from other guys that race.
It only makes cents.
That's the way I've seen it as well. I always ran 87 octane regular in my '16 1LT V6. During the break-in period of my '21 3LT V6, I ran 91 octane premium, just because. But other than that, I have enjoyed the price advantage of being able to run the LGX on regular!
On the other hand, it's only premium for the '74 460 Ranchero and '73 5.0 RHO Maverick...
Old 10-13-2023, 06:55 AM   #30
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
91... 93 isn't very prevalent around here. Never have had any issues with 91. I've run it in all my cars, motorcycles, small engines... etc.
jamala00 is offline   Reply With Quote
Old 10-13-2023, 05:51 PM   #31
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by Gen6cyl View Post
Runs better, tuners say so . Let's ecu advance timing. Same compression ratio as 6.2 lt1.I used 87 octane for the first 18 k miles, since then have been using 93 octane.
I agree. The 3.6L V6 got DI and VVT first, with the resulting higher comp. ratio and output. We had to wait for the LT1 for those advancements in the V8 engine. I had the 5th gen car with the 1st gen V6 and always ran premium in it for maximum performance and engine protection.
Ventmaster is offline   Reply With Quote
Old 10-14-2023, 11:25 AM   #32
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I've never run higher than 91, nothing much higher around where I live unless it's avgas. Don't octane boosters mess up catalytic converters and change the spark plug colors? That was my understanding from the many threads on here through the years about it. I hope I'm wrong though
Old 10-14-2023, 11:29 AM   #33
jamala00
jamala00's Avatar
I use 91... 93 is not readily available around here. I've run 91 in all my cars, bikes, small engines forever... Never had any kind of issues. Honestly I wonder if someone went and put gas in my car and I didn't know which they put... 91 or 93, wonder if I could actually tell the difference. I'm guessing not.
Old 10-14-2023, 04:12 PM   #34
Ventmaster
Ventmaster's Avatar
I think the general consensus is that a great many octane boosters are snake oil. After I put a procharger on my V6 I figured I better boost the gas and got the brand held in highest regard by the FI experts on the 5th Gen site. Can't remember now what that brand was but sure enuff when I pulled a couple of spark plugs they were a very weird color. When I posted a pic on Camaro5 everyone said, "Stop driving it and get it to a shop!". But the car ran great and without issue. I did eventually quit using the booster and the engine continued to run fine on 91.
Old 10-14-2023, 04:23 PM   #35
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
My thought is try and use a gas station that is frequently used so the turnover rate is high no matter what octane
Old 10-14-2023, 06:17 PM   #36
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Yes , 93 is the least bought gas. At a slow gas station 93 could be old.
Gen6cyl is offline   Reply With Quote
Old 10-14-2023, 07:26 PM   #37
Summit20171SS
Summit20171SS's Avatar
Drives: 2017 1SS M6
Can you run Cam 2 Unleaded 100 Octane gas in the SS's? Like mix it half a tank of 93 and the other half Cam 2 100 Unleaded?
2017 1SS M6
~ Air Raid Cold Air Intake~ ~ 3" Corsa Extreme Catback Exhaust ~
Summit20171SS is offline   Reply With Quote
Old 10-14-2023, 08:40 PM   #38
ABM1SSSG3
ABM1SSSG3's Avatar
Drives: 2017 SS ABM A8
Yeah, the first time you see that rust color all kinds of things run through your head, especially if you pull the heads and look at the chambers & valves. If you pull the plugs for an analyzation, it will be non-conclusive with that stuff on them.
2017 ABM SS A8 GM big brake kit SG3 Lowering & SC1 sway Bar Kits GM OEM SS 1LE wheels
ABM1SSSG3 is offline   Reply With Quote
Old 10-14-2023, 08:45 PM   #39
ABM1SSSG3
ABM1SSSG3's Avatar
Thumbs up
I have a Union 76 station nearby that sells VP101 (unleaded with California additives) at the pump. we don't have 93 here, so I mix 5 or 6 gallons of that with the rest 91.
Old 10-14-2023, 08:46 PM   #40
02blackss
02blackss's Avatar
Drives: 2023 ZL1 Convertible
Originally Posted by cariboocreek View Post
Yes. Even the Canadian version of the Owners Manual indicates 91 octane as the recommended. Only the big cities may have a Chevron station with 94. I have ran Canadian 91 in my Camaros, Vettes, and Mopars for years. Never an issue.
In Ontario 94 Octane is widely available at almost every Petro Canada…
That’s what mine gets…
Jason
2022 Equinox RS
2023 Trailblazer RS
02blackss is offline   Reply With Quote
Old 10-14-2023, 10:52 PM   #41
Some might be snake oil, but the relevant ones that everyone talks about and that come up in internet searches (Boostane, Torco, Race-Gas, maybe others) contain non-negligible amounts of MMT and they simply work.
I have back-to-back HPT data logs from the same track, same day to prove that Race-Gas immediately eliminated clearly present knock retard altogether, which means it must have tangibly increased the octane level of my 93 pump gas.
As a result, I'd be a bit less forthcoming about any "snake oil consensus".
Now, as to how detrimental the orange discoloration on spark plugs they cause is, or whether these have long term "cat killing" properties is a discussion worth having, but these are not snake oil---they are explicitly disallowed by GM, but they do work.
Old 10-15-2023, 04:50 PM   #42
Summit20171SS
Drives: 2017 1SS M6
Thats awesome! Do you feel the car run smoother or little better performance wise? I bet it has a nice smell too!
2017 1SS M6
