#29 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
It spun a little you can see it on the gmeter. I have 20x11.5 rears with 325/30/20 R888R’s.I always do a rolling burnout in first before doing runs. Need to go out now that the car is aligned with zero camber. I also had the drag mode flash done for the chassis module that increases clutch pressure in the ELSD. Should hook even better. ZL1 comes with 1.5 degrees of negative camber from the factory. Not good for straight line traction.
#30 | |
Drives: 21 ZL1 Join Date: Feb 2022
#31 | |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
#32 | |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
#33 |
#34 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Try instead watching Throttle Position, not the SAE, but the next one down in the list that has a single blue arrow, not 2 of them. This one has given me 99.6% readings at WOT. Commanded Throttle Actuator (SAE) read 100% at that time and also 100% on Throttle Desired Position. Screenshot below of when picking the channels that gave these readings in ECM>Engine>Accelerator & Throttle>Throttle section of VCM Scanner. |
#35 |
Winter came early here in Missouri also, November is usually pretty decent and couple weeks back it was, last week was cold and windy with 4 inches of snow. This week look pretty good upper 40 to low 50. Traction on my car at 50 degrees even with drag radials in non-existent at 50 mph, at 60 mph it's starting to hook after that. My old red 16 ss when it was making big power was non-existent at 100 mph on street tires. I think the 888s probably do as well as my drag radial 555r2s do on the street on a roll. Supposedly a pretty sticky street tire. If I'm street logging in cooler temps I'll do a couple burn outs to put some heat in the tires, traction control has got to stay on or its ditch to ditch.
King did a great write up for everyone so thanks for that. |
