Old 06-03-2022, 09:14 PM   #29
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Ideally he needs a 27.5 in the front and a 28 in the rear. since he is not willing to change the front then he might as well just put a 305/30/20 555r2(27") on the rear and call it good enough. That tire has been 9.9's on a C7ZR1 with good track prep.
27.2 inches diameter on a 305 30 20
lt4camaro is offline   Reply With Quote
Old 06-05-2022, 09:43 AM   #30
6spdhyperblue
Drives: 2SS 1LE
They hold pretty well depending on the type of pavement. I'm running about 29 psi in the tires, on concrete I can get on it from a dig and barely breaks the tires loose. Asphalt depending on how rough it is does really well also. Smooth asphalt nothing hooks very well. At least I can log now without blowing the tires off at the hit. My G2s wouldn't hold at all, sideways Jonesing thru 2nd gear.
What do you guys think about just going with the stock size NT555RII
275/35R20
Do you think they’d give up a lot of traction at this power level?
They are a bit shorter and narrower
I imagine the 305s look better tho. Do you have any pics of it?
Old 06-05-2022, 10:22 AM   #31
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
275/35/20 is stock size...either way I would get the 305...it fits fine, looks fine, and works great. Been running them for years now.
Also 29 psi won't give you full traction. They need to be down around 23psi for full send mode.
Old 06-05-2022, 11:20 AM   #32
JSH
JSH's Avatar
Drives: '20 ZLE
Nice pic. First time I've seen your car.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 06-05-2022, 12:38 PM   #33
lt4camaro
lt4camaro's Avatar
I agree, just go with a 305 30 20 .
Old 06-06-2022, 09:27 AM   #34
KingLT1
KingLT1's Avatar
Old 06-06-2022, 11:10 AM   #35
6spdhyperblue
Drives: 2SS 1LE
Looks good. I like the beef back there
Old 06-06-2022, 05:32 PM   #36
KingLT1
KingLT1's Avatar
Thanks! Yeah I am old school. I still like chrome and a beefy tire outback.
Old 06-06-2022, 07:04 PM   #37
laynlo15
Drives: 2022 Lt1 A10
305 35 20 on 9.5 stock wheel and my car is lowered on Phastek springs. I love the look of the big tire on the rear. It tucks right up under the wells.
Old 06-07-2022, 07:26 AM   #38
6spdhyperblue
Drives: 2SS 1LE
Looks good..and that back drop
I have them in my cart on jegs. Hopefully I can move move my 17s and the extra parts I have laying around lol
Old 06-07-2022, 11:18 AM   #39
laynlo15
Thx, I live in the midwest amongst 1000s of acres of farmland.
Old 06-07-2022, 12:21 PM   #40
cjperformance
cjperformance's Avatar
I live in St. Louis amonst 1000s of acres of hills and curves.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 06-07-2022, 09:16 PM   #41
laynlo15
You sure do. When you getting to the track again?
Old 06-08-2022, 08:15 AM   #42
cjperformance
Ordered NT555R2s in 305/30/20 to go on my 20x11s. I can vouch that the NT05s were a poor choice. The 555R2s are back ordered for a month or so.
WWT has no drag events, at least no WOW or MM until July. Prob still cleaning up from the Enjoy Illinois 300. So will get back after they open and when I've got my new tires. I might try a few runs with the NT05s and then the 555R2s. I like comparing small changes to see the difference. Between last time and the next time out I'll have the Trans tune, converter, and DS different already.
