Old 12-29-2021, 05:10 PM   #29
Z OH 6
Drives: 2024 CT5-V Blackwing
Cam, heads, headers, and lower now will get you 720 wheel, and you'll have a valve train that will work with the 2650.
The stock valve train will work with a 2650 too, however I think the point you are trying to make is that the 2650 isn't needed until the high side fueling is upgraded. Like KingLT1 said, there are other options now besides a cam to address high side fueling.
Old 12-29-2021, 05:27 PM   #30
JSH
JSH's Avatar
Drives: '20 ZLE
When I typed that I was actually thinking of doing the work I said now, and then adding the 2650 later and maybe even with meth / eth. which of course could exceed his hp goals
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 12-29-2021, 05:57 PM   #31
airtroop01
Drives: 2018 Cadillac CTS-V
I did 678rwhp with a 2650, 103mm snout, TB, and CAI and stock everything else all the way to the factory 4 cats and 91-octane gas.
If headers/cats were not a constraint, I am pretty sure we could have gotten 700rwhp with that combo.
I did 808rwhp with the 2650, 103mm snout, TB, and the toohighpsi plates/injectors pushing e85... stock cam/stock injectors.
airtroop01 is offline   Reply With Quote
Old 12-29-2021, 06:06 PM   #32
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by ChadSZL1 View Post
I currently have csp long tubes, mid pipe no cats, awe exhaust, intake, 95mm TB, flex sensor, plugs, wires, and jms voltage booster. On 93 601 tire and on E60 644/676 no pulley change. Budget 4-5 grand. I also plan on getting the TCM tuned
The OP has all this. So won't just fuel (injectors, pumps) a healthy lower pulley, a trans tune and rear drag pack (and perhaps a driver mod) get him to 700 whp and low-mid 10s?
For 9s yeah I agree a blower change with associated accoutrements for 800+ will likely be needed to overcome the extra weight of the cage.
Old 12-29-2021, 06:24 PM   #33
airtroop01
Agree that what with he's got already... a Kong X-Port would get him there (700rwhp)... or a 2650... or maybe just a pulley change (with the associated heat that comes with that).
Old 12-29-2021, 06:38 PM   #34
Z OH 6
Yes, which is why I recommended just a ported blower and pulley along with his current mods should get him very close. Drag pack, possibly TCM tune and the right track conditions with practice should dip into the 9s.
Old 12-29-2021, 06:50 PM   #35
JSH
JSH's Avatar
Drives: '20 ZLE
Looking closer at his post #4, and if all he wants is 50 hp or 700, one of Kong's ported Eaton blowers is all he needs, but not if he's certain he's eventually going to a 2650, in which case, a custom valve train sets the stage for a 2650.
A 50 shot is by far the least expensive way for him to get to 700 and not spend twice on blowers.
2020 ZL1LE A10.
Old 12-29-2021, 07:16 PM   #36
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
I can do the cam install myself so that saves a lot of cash. The injectors, high side pump, and DSX low side would be more expensive I would think in parts cost alone. If I went that route wonder what hp I could see with my current setup and a lower pulley
ChadSZL1 is offline   Reply With Quote
Old 12-29-2021, 08:01 PM   #37
JSH
JSH's Avatar
Drives: '20 ZLE
I'm not sure how much cam you can put in it before you change valve springs and other valve train parts, but a decent cam and lower might give you close to 50 hp.
2020 ZL1LE A10.
Old 12-29-2021, 08:20 PM   #38
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
The downside to a ZL1 running 9.99 or quicker is a roll bar is required, I believe.
The upside to racing at 8-10000 ft DA is my car won't run 9s.
I was told NHRA new rule for cars newer than 2014 dont need a roll bar until 8.99 now!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 12-29-2021, 08:36 PM   #39
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I just started a thread about that. I heard that rumor and was hoping it was true!
Old 12-29-2021, 09:49 PM   #40
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
If you can do the cam yourself, pull that motor and hit your goal. The labor is what would put that out of budget for most folks.
Good luck either way, you’ve got many options to sift through lol
jvandy50 is offline   Reply With Quote
Old 12-29-2021, 10:24 PM   #41
ChadSZL1
Red Bull
ChadSZL1's Avatar
You guys have my mind running thinking of all the possibilities and different setups to reach 700 RWHP and hopefully dip into the 9s. I really miss the sound of a cam…… my C7 was fully built and that chop is amazing! The ported blower with a lower on like E 40 ish would probably also get me there. My goal is to hit 9.90s this next year. I feel like with 700 tire, drag pack which I already have (weld s-71s), and tcm tune I think it can happen with great weather. But I definitely want to have 800 plus in the next few years
Old 12-29-2021, 11:57 PM   #42
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Did the video not show up in my previous post? I see it on my end.
Jorge's ZL1 A10
Flex sensor
Rotofab big gulp
Headers
Weld Laguna drag pack
E45
Pray ECM/TCM tune
1.5 60ft 10.1 @ 135 1/4 mi
1300da @ HRP
No blower port, no pulley. Would of likely already made a 9 second pass if life didn't get in the way.
You don't need a cam or larger supercharger to run 9's with these cars. Add blower port, pulley, fuel system, and 9's should be doable in average air.
