11-16-2021, 07:05 PM | #29 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
I would say with a 9.17 lower and a JMS booster you should be able to run E45 safely. I should know here in a few weeks.
11-16-2021, 08:01 PM | #30 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
11-17-2021, 06:39 AM | #31 | |
Like I said above burning better fuel is always a win win. Our systems are designed from the ground up to run E fuels there is no down side other than fuel economy for commuting. Ted.
www.jannettyracing.com
11-17-2021, 07:05 AM | #32 | |
But only logging will tell for sure. I promise your not making 697 RWHP on the street and when it pulls 4 degrees which is a direct result from spinning the blower too fast and too much boost for pump gas. You will have a much happier more consistent combination for sure. Ted.
11-17-2021, 07:11 AM | #33 | |||
I do also have experience with ported blowers and honestly they are not that much better unless your on the dyno chasing numbers, Icing it down, for that glory number. The intercoolers with in the supercharger can not handle the additional heat loading for any period of time past about 5 seconds. The dyno is a great sales tool when used wrong. Ted.
11-17-2021, 09:04 AM | #34 |
Red Bull
What would be the next upgrade to Teds 125 road race package if you wanted another 75-100 RWHP? I know the cam and 2650 make around 840 ish according to Ted. But what could you do to see around 730-750 tire?
11-17-2021, 09:20 AM | #35 |
Heads/Cam....Probably be low 700's on stock boost with 93. If you do +30 injectors and low side then you could probably run E85 without mixing(barring it's not station that has unusually high E content) on stock boost and make consistent 750-760whp. You might even get away with E40-50 on stock fueling with bigger fuel lobe cam.
2016 NFG 1SS A8
11-17-2021, 09:38 AM | #36 | |
Red Bull
11-18-2021, 07:23 AM | #37 | |
Cam and heavily modified stock blower is the other which just does not make sense to me, the money you will spend on porting, big throttle body and pulleys plus it would be a dyno queen and not real power you can carry to the street, or track I was on the dyno last night with a stock long block LT1 1LE we did our terminator package on, it made 764 RWHP on pump gas needless to say I was a bit blown away, since the car made 727 RWHP when we originally built it during the summer. We had crazy good air last night.
11-18-2021, 01:11 PM | #38 |
Red Bull
Thanks Ted for the response! So if you had to do it in steps I would assume you would suggest to do the cam? What kind of RWHP would that add? Then later add the blower. That sounds like a great plan!
11-18-2021, 01:24 PM | #39 | ||
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
11-18-2021, 01:29 PM | #40 |
I personally would not do it in stages. I think it is better to save up and do it all in one shot. But if I did do it in stages then I would get the cam, ported heads, and LTs out of the way first as those all are the most labor intensive installs. Once you get to the cam you might was well just also go ahead and take the heads off and once you take the heads off you might as well just go ahead and do the LTs. From there I would not even bother porting or pulleying the blower since the goal is to replace it anyway. Lastly I would do the blower, any fuel mods, and suspension mods, a chiller if in the budget (not necessary tho), and any other supporting mods (gauges etc).
11-19-2021, 07:24 AM | #41 | ||
We have to tune, VE, TQ, and MAF so it's like tuning the car 3 times per session. Ted.
11-19-2021, 08:07 AM | #42 |
Thanks for the feedback Ted, I may go back to a stock lower pulley at some point, install a flex fuel sensor. I assume at that point you could activate the flex sensor and remote tune it. it already has all other bolt-ons.
