#29 |
![]() Drives: 2009 Pontiac G8 Join Date: Sep 2018
You can absolutely get by without the camber plates. Follow the mod in the link below and you can a little more over stock. Some have been able to get close to 3.0* by doing this.
https://www.camaro6.com/forums/showthread.php?t=526353 |
#30 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Gotta be honest, I find a 26mm spacer alarming. I've never heard of anyone tracking anything close to that. You haven't had any issues? How much do those things weigh?
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#31 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Assuming they are machined from aluminum - which they should be - spacers aren't very heavy in the context of any typical Camaro6 wheel/tire combo. Even if they added a whole pound of unsprung weight (which I seriously doubt), that's still less than 2% of a typical wheel/tire combo.
Matt Miller
2020 SS 1LE |
#32 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
At least Apex's 26mm spacer appears to be of the slip-on variety. The extra set of holes looks like it's more for weight reduction than anything . . . don't both the 5th and 6th gen Camaros take 14mm wheel studs? Norm
'19 WRX 6M (the family sedan . . . seriously) |
#33 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I think there can be issues in some cases, so I do see your point. If you add a lot of extra offset vs stock and use much larger/wider/heavier wheels and tires with a lot more grip... like putting 265 width autox tires on a 90's Honda Civic, yes you may have issues due to more leverage as well as more stress on the wheel studs. On the Camaro application the offset is about the same as a ZLE and the wheel studs are seeing similar loads, also the spacers retain the centering function so the wheel studs won't see shearing loads. The spacers weigh about a lb or so, it's not much and the overall weight of the wheel/tire/spacer combo is still a lot less than stock. Also, APEX sells this setup and recommends it, they aren't going to do that without assessing their potential liability. I do think you have to be careful... We recently almost had an incident, a wheel broke off of an old VW Scirocco running slicks probably 4x as wide as the stock tires. The car almost flipped, gas leaked, the wheel/tire nearly hit a GT4 in grid. In this case the stock rear axle broke! So yeah, modifying old 90's econoboxes can be sketchy as no part of the car was ever intended to see the stresses of big tires and more power.
#34 | |
One of the reasons I love this board. I really appreciate the responses. I agree that Apex is a reputable vendor. I have a set of their wheels now, but would LOVE to go 305 square with the ability to rotate. My wife and I are planning on OLOA in 2022 and this would be a big help. I see what you are saying about the results of the spacer retaining close to factory spacing. Did you only have to go 1" longer with your wheel studs? Again, thanks to Matt and Dave for those great responses.
2017 HBM SS 1LE
#35 | |
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 I got these lug nuts, it's hard to find good ones these days it seems. So much junk out there! The knurl on these covers the studs when you're not using the spacer. Looks better than the short ones imo. http://1320performance.com/index.php...tegory&path=95
#36 |
Small correction here: studs with properly torqued lug nuts never see shearing loads, whether there's a hubcentric wheel/spacer or not. All shear force is taken by the friction between the wheel's mounting surface and the hub face. The studs' only function is to supply the clamping force that creates that friction. If your studs are seeing shear force, then the lug nuts were either not tightened nearly enough, or they were over-tightened to the point that the studs permanently stretched and no longer supply enough clamping force to hold the wheel in place.
Matt Miller
2020 SS 1LE |
#37 | |
I only mention it as a feature of the Apex spacers, they are made specifically for the Camaro. The primary function is to center the wheel to prevent vibration, but they would also prevent shear in cases where something else went really wrong.
#38 | |
Matt Miller
2020 SS 1LE |
#39 |
For lugs, I already knew I was getting new studs, you don't like the dorman lugs?
https://www.summitracing.com/parts/rnb-713-685t
2017 HBM SS 1LE
#40 | |
#41 |
![]() Drives: 2016 2SS 6MT Join Date: Apr 2020
Stumbled back on this thread. I ordered the camber plates with my wheels from Apex to run 305/30/19 square ET35 more than a year ago. Everything arrived quickly except for the ARP studs. Consequently, I haven't been able to install the wheels. Its been over a year. Insane.
#42 | |
