Old 05-14-2021, 02:50 PM   #29
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Originally Posted by AZ_1LE View Post
Just keep in mind that we don't have normal old-school pumps in our engines which build pressure linearly with RPMs like you might be used to. We have variable vane pumps which maintain certain pressure levels and is controlled by an electronic solenoid, mainly to improve gas mileage. GM determined that there's no real need to have 70+ PSI of oil while you're cruising on the highway, but if you put the engine under a load, the solenoid will move the internal "parts" of the oil pump to make it start producing higher pressure.
As always, increased complexity increases potential for problems. Is the housing cracking or other parts?
It's kind of an ingenious design, but the earlier versions of it were prone to cracking as we all know. I do kind of wish they had just put in a regular pump, but, EPA........
Yeah the same regulations that brought you wonderful innovations such as AFM
ZX-10R is offline   Reply With Quote
Old 05-14-2021, 02:51 PM   #30
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Originally Posted by Spaceme1117 View Post
I purchased a used 2017 2SS about 2 months ago. CarFax showed that it had to have the oil pump replaced.
Did you get a discount based on the oil pump issue?
SFV1LE is offline   Reply With Quote
Old 05-15-2021, 09:28 AM   #31
Dave777
Drives: 1985 Z28
Does the LT4 in the Z06 Vettes have any problems ?
I do know the Z06 has a dry sump oil system.
Dave777 is offline   Reply With Quote
Old 05-15-2021, 11:54 AM   #32
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
There is a thread on a corvette forum with oil pump problems for the LT4.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is online now   Reply With Quote
Old 05-17-2021, 02:32 PM   #33
nighttowl
nighttowl's Avatar
I just recieved a call from the dealership, they are going to open a case with GM to see what to do.
Old 05-17-2021, 07:54 PM   #34
Trak-Toy
Trak-Toy's Avatar
Drives: 2023 SS 1LE
Good to hear. At least now it’s been documented as a ‘potential’ issue with your specific car for warranty purposes. Let us know how it goes. May help some of us in the future.
Trak-Toy is offline   Reply With Quote
Old 05-18-2021, 09:51 AM   #35
ZX-10R
ZX-10R's Avatar
Ideally they would replace the pump before it actually fails, it will be interesting to see how this plays out. There should be some threshold pressure below where they say it's cooked (e.g. 25 psi hot idle)
Old 05-18-2021, 10:25 AM   #36
ZLE dude
Drives: '18 ZL1 1LE
100% agree with this statement. I've been trending my oil pressure for the past 15K miles and it's never been below 27psi hot idle...EVER. That's why I have an alarm setup if my oil pressure is ever below 27 because that would be a significant change to the norm and indicate I have an issue starting. That's one thing I like about external gauges that can be handy instead of the silly dash gauge.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 05-19-2021, 11:10 PM   #37
nighttowl
nighttowl's Avatar
Gm is sending a field engineer out to look at it, although they did not say when.
I hope I dont get screwed...
Old 05-20-2021, 07:20 AM   #38
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
You won’t get screwed! You still have drivetrain warranty on your 2018 and if it fails they will replace it. I hope the best for you.
Old 05-21-2021, 07:14 PM   #39
nighttowl
nighttowl's Avatar
Just picked up the car.
They changed the oil in it and pushed it out the door.
no change, 21 PSI hot oil pressure at idle.
They said that GM low limit is 22 psi at 1000 Rpm, so im good to go.
I guess ill either sell it (because there is clearly nothing wrong with it) or drive it until it stops running.
Old 05-21-2021, 08:05 PM   #40
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Hmm... that’s too bad. I just tried to put myself in your shoes... Not certain what I’d do.
Old 05-21-2021, 08:24 PM   #41
nighttowl
nighttowl's Avatar
Could make some sarcastic license plate images to display your frustration.
Old 05-21-2021, 09:21 PM   #42
LT4Greg
LT4Greg's Avatar
Drive it till it dies nighttowl! That’s what I’m going to do with my 2017!
