Old 04-11-2021, 12:49 PM   #29
CC2018SS1LE
Drives: 2018 Chevy Camaro ss 1LE
Originally Posted by MatthewAMEL View Post
PB is a 2:28 on OEM tires.
I'll be there with NASA on 4/17-18 to see if I can shave a few more tenths...
Nice time
Good luck!!
CC2018SS1LE is offline   Reply With Quote
Old 04-11-2021, 01:13 PM   #30
JSH
JSH's Avatar
Drives: '20 ZLE
All of those engine clearances that Chevy has worked so hard to perfect become increasingly penetrable as RPM and oil pressure increases.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-11-2021, 05:40 PM   #31
weemus
Drives: 2017 1SS 1LE
No oil comsumption for me. Must have missed you N Camarolina at CMP. I was the black 1LE running in advanced.
weemus is offline   Reply With Quote
Old 04-11-2021, 07:58 PM   #32
CC2018SS1LE
2nd vote for this.
My oil pan bolts were working loose after about 2 years. Tightened them and haven't had any seepage since.
As for oil consumption, as of 40K miles and LOTS of track days, I burn 0 during an event. I've never added more than 1/4 qt between oil changes.
OP - that much consumption during ONE event is concerning. Modern engines just don't burn oil. If they do, something is wrong. I'd find a shop (or DIY) to perform a compression check.
If bolts were loose, you would see oil stains when parked
I have no stains at all under my car
I will ck when I get back to Florida
Thx
Old 04-11-2021, 08:15 PM   #33
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
2:28 is smoking... I believe 2:34 is my best, I claim poor skills and old age 58
Timbo-1LE is offline   Reply With Quote
Old 04-12-2021, 01:20 AM   #34
cdrptrks
cdrptrks's Avatar
Thx
I had no stains under the car either time but it was just a single slightly loose bolt in each case for me. I guess I caught it quickly enough both times that oil only seeped significantly while driving hard on track.
Old 04-12-2021, 10:19 AM   #35
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
zero oil loss here and over 50 track days
Old 04-12-2021, 10:21 PM   #36
CC2018SS1LE
I will def ck when I get back to Florida
thx
Old 04-12-2021, 10:24 PM   #37
CC2018SS1LE
My 2017, never used oil either. I will investigate before I go back to Sebring at the end of the month
Thx
Old 04-12-2021, 11:05 PM   #38
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Weemus, I rented a garage so facilitate changing wheels (I use the OEM wheels/tires for the track and a separate set for DD). I think I saw your black 1LE parked under a tree near the form-up line to the pit/track entrance. I didn't see you on-track, as I was running in intermediate group - my first time at CMP and my first time driving my 1LE on track.
Got used to it pretty quickly though and was turning 1:50 by the end of the 3rd stint. Probably would have been in the high 1:40s if I could have run a lap without needing to let up for slower traffic. The SS 1LE is a truly amazing car!
N Camarolina is offline   Reply With Quote
Old 04-13-2021, 10:12 AM   #39
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
CC2018SS1LE, My experience with oil consumption on track days led me to make 2 changes.
when it is warm out, which is most of the year around here, I run the 15/50 Mobile 1 that is recommended for the ZLE.
I also short shift ~ 5500-6000 RPM rather than run out to the red line.
I've seen several improvements from this: lower oil temps, longer oil life and less oil consumption. Prior to these changes, the catch can would fill up every session. now i can go 2 days and have ~ 1" in it.
FYI the catch can won't stop oil consumption, it will keep it from caking on your intake valves........only if you empty it and/or it doesn't fill up in one session.
Something else, IMO having a catch can will help save your CATs when running the 15w50 oil. It'll keep the phosphorous, which is in the oil, from damaging the CAT material. During summer I'll run the 15/50 full time. I don't change after each track day.
Good luck!
Old 04-14-2021, 11:12 PM   #40
CC2018SS1LE
Good luck!
Makes a lot of sense
I have to change oil before I go back to Sebring, I’ll put the thicker oil in
I also ordered a catch can, going to install before the track day
Can you put the oil from the catch can back in the motor, or, just throw away?
Thx
Old 04-15-2021, 11:08 AM   #41
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Thx
I dispose of the oil, when you smell it there is a gas scent. I feel as though it would thin the oil in the crankcase if it was poured back in.
Old 04-15-2021, 11:30 AM   #42
CC2018SS1LE
Thank you
I Do not want to thin, the oil
I never smelled the oil, since I am installing next wk
