#29 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Yup. Sorry. Just noticed I posted it wrong initially. I was auto-responding to the 'bleed farthest from the master cylinder' myth that seems to persist. Thanks for the heads-up. Glad we agree with the manual.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#30 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
"KEEP THE FAITH"-Fbodfather |
#31 | |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
#32 |
The MityVac comes with hoses and ends that tightly fit over the bleed nipple on the caliper. Loosen the cap on the reservoir, attach to the bleeder, pump the handle a few times to build vacuum and then open the bleeder. Every 30-45 seconds, pump the handle and watch the fluid in the hose. The Motive (the other recommendation) works, but there are some caveats that drove me away...you need the correct fitting for the brake reservoir cap, you have to be careful not to over-pressurize the Motive or it will drive brake fluid out and all over your engine bay and I always found myself pumping up the Motive, going to the bleeder on the caliper, opening into another bottle for the drained fluid, and then going back to the Motive to pump it to keep positive pressure. The MityVac is much easier because everything happens right there next to the caliper. You simply go top off the fluid between each caliper. It's also awesome because you can do oil changes and transmission fluid changes without having to pull drain plugs. You pump them out.
2017 HBM SS 1LE
#33 | |
So your using the MityVac to suck the fluid instead of the Motive that pushes the fluid. Snice the MityVac sucks do you happen to notice if you see false air bubbles in the hose ? |
#34 |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
Exactly right! SRF is maybe 50% more whereas I first thought it was 3x the price. In total, it was only roughly $20 more.
#35 | |
Yup. You see very small stream of bubbles from time to time. But as long as they are moving swiftly away from the caliper and into the tank, it's working.
2017 HBM SS 1LE
#36 | |
Just placed an order for the Motive and SRF. Let's see how the Motive works if not I will.give the MityVac a try. |
#37 | |
Be sure to get the ‘black’ series Motive. The plastic cap has a habit of flexing and losing pressure.
2017 HBM SS 1LE
#38 |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
I personally use the Motive with an old 2L soda bottle and fill the Motive bleeder with fluid then just go around bleeding
#39 |
#40 |
![]() Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
So last year I ran Motul 660, this year I'm switching to SRF. I bought the Motive power bleeder but can we touch on the subject of knowing how much fluid to push thru each bleeder in order to know you've completely changed your fluid? I have two bottles of SRF and I don't mind using them both but I want to be sure I flush all the 660 out.
#41 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
Then you will hear you have to activate ABS solenoids to get everything out of there, but I've never done that and you need the dealer tool for that. Sucks to waste fluid especially the expensive SRF, but I've seen some people say that the total capacity is less than 1L and some say it's more so that is why i say just do alot ![]() If they allowed colored fluid anymore that would be nice.
Old Ride: 2016 Callaway SC630 Camaro SS
#42 |
![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
For the first flush I did, I put fluid in the motive. It was nice being able to fairly quickly go around to each caliper and bleed without worrying about the master running dry. I was also a bit paranoid about it leaking and blowing fluid everywhere, so I had my kid watching the MC to be sure it didn't get out of hand.
It was a bit annoying to clean all the fluid out of the motive afterward, using denatured alcohol and then making sure it was properly dry before putting it away. Just from the annoyance of cleaning it, I switched to using it dry without fluid. Now I just use it to pressurize the MC and pull the cap to add fluid between corners. |
