Old 01-26-2021, 06:32 AM   #29
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
Originally Posted by Bangkok_ZL1 View Post
You know, I have seen jack stands rubber adapters. If I wasn't buying my own lift, I'd buy these rubber adapters along with my stands. Those AddOn lift pads were a life saver for me though. Can't rave about them enough. I saw it in action, when these Thai mechanics would have really messed up my car. I'm so lucky to have listened to the forum members that suggested these. I can't thank them enough, really. But they did forget to tell me to be careful and go very slowly over steep speed bumps (slightly touched the lift pad once)....
Hey go slowly over bumps you may scrape also if you hit the right pedal to the floor on cold tire or in the rain you car will do magic tricks... lol I kid i kid im still excited for you and your car. i remember your first post glad the excitement hasnt worn off...
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 01-26-2021, 03:24 PM   #30
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Originally Posted by Alain View Post
I can't wait to have a garage big enough to install a lift !!
I've got a Tiny One Car Garage and I stuffed a 4 Post lift in there!
Old 01-26-2021, 05:27 PM   #31
20Bluezl1
You have a bigger Garage then me. I wish I had space like you I'm trying to do some work as we speak and not fun at all. Not sure if I went over my head .🤦🏻*♂️
Old 01-27-2021, 03:04 PM   #32
BMR Sales
BMR Sales's Avatar
Drives: Race Car
That is Small!
Old 01-28-2021, 09:14 PM   #33
UFDUB
Drives: Chevrolet Camaro ZL1 1LE
(.....that’s what she said)
UFDUB is offline   Reply With Quote
Old 01-29-2021, 03:17 PM   #34
Alain
Alain's Avatar
Originally Posted by NiteBlitz View Post
I just checked out their website briefly. Looks interesting, where to they grab on the bottom. Im assuming it doesn't destroy the side skirts.
The quick jacks are worth their weight in Gold if you don't have the ability to have a two or four post lift. They come with rubber blocks you use to place between the quick Jack and the jacking points on the car. It does not damage the side skirts.
I recommend you go on Amazon and buy yourself four magnetic Jack point pads that you would attach with magnets to the pinch welds on the car. The rubber blocks that come with the quick Jack will make contact with those as the car good up. The quick jack never makes contact with the car.
Originally Posted by CW3SF View Post
You can easily change tires on a 4 post lift. I do it all the time on mine. I have a Jack that slides down the center track of the lift and has arms that are adjustable inside to outside. I can lift either the whole front end or the whole rear end off the car off the wheel paths. I also have a Jack tray that I can use and raise all 4 wheels off the lift at the same time.
It’s not just an extra parking space.
Did that Jack that goes up and down the center of your four post lift come with it?
People don't realize you can also use a set of quick jacks while the car is on the four post lift to get all four wheels off the ground simultaneously.
That's is the setup plan on when I get my home garage set. I already have the quick jacks, just need the four post lift.
2018 ZL1 1LE/Red hot
Old 01-29-2021, 07:11 PM   #35
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
The sliding Jack is an option that you can get when you buy a new lift.
CW3SF is offline   Reply With Quote
Old 01-30-2021, 11:20 AM   #36
Alain
Alain's Avatar
Copy that.
Thank you
Old 01-30-2021, 05:56 PM   #37
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Originally Posted by MatthewAMEL View Post
That's a 'parking lift' not a working lift.
Gives you two parking spaces.
For the most part I agree but I use mine to do lots of projects and it comes with a jack tray that I have used many times. I usually either jack the front or the back wheels at the same time. its a little harder to get all 4 in the air at one time.
pauly1119 is offline   Reply With Quote
Old 02-01-2021, 09:34 PM   #38
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
OMG, Is that the old 914? My neighbors across the street had one when I was growing up in California back in like 74 I'm guessing.
Bangkok_ZL1 is offline   Reply With Quote
