#29 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
yea i just added the spl toe rods last weekend before the track day but left the rear at -1.5 for now only issue is i dont have stock struts so not sure if the camber plates will work without mods to them
#30 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Aragorn, for your driving scenarios, I don't think the stock GY SC3 has any advantages for you. They certainly are fast on track and almost as fast as the best 200tw tires for autocross, but they pose real compromises for street driving, as others have outlined. I would not go with an all-season for your uses. I agree with those who think you'd be better off with the "max performance summer" category of tires. Without question, the two best in that category are the Michelin PS 4S (which, to clarify, is not an all-season tire at all) and the Continental ExtremeContact Sport. They are both great for dry grip and wet grip, work well in any temps above freezing, and will be quieter and last longer than the GY SC3. In terms of outright performance, the Michelin has a teeny (and I mean really teeny) advantage over the Conti, but the Conti is about $250 cheaper for a set of four and is so close in both wet and dry performance as to be indistinguishable without a controlled test (and maybe even then, also). If you work out a deal with the forum member for his set of Michelins, that's great. If not, I'd say get the Contis and don't look back.
Matt Miller
2020 SS 1LE |
#31 |
![]() Drives: '23 Hyundai Kona N, '24 VW GTI Join Date: Aug 2019
They are pretty damn good tires. I don't know that there is a tire that is as fast on the track or autocross that also holds up for daily driving 365 days a year.
#32 | |
lol daily driving? whats that btw we live in cali so its a lil different for us!
#33 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I do notice a bit more 'wiggle' in the rear when making aggressive lane changes. The biggest problem I've had happened a couple of weeks ago. I made a quick left hand turn on slightly uneven pavement and within a few minutes got a low pressure warning on the driver side rear. It went flat pretty quickly. The repair kit was unable to re-inflate the tire, so I had to have it put on a flat bed and taken to the local Chevy dealership. They were unable to find anything wrong with the tire and speculated that the bead wasn't correctly set when the tires were put on and it popped off the rim when I made that corner. I had it installed at my local dealership and I do remember the tech mentioning he had a hard time getting the tires on the rims. The same tire is still on and no problems since then. |
#34 | |
I commute about 60 miles a day on them, do track days, autocross a lot, and they hold up. |
#35 | |
I've drivin it many times in 20-30F temps on sunny days in Denver and other than being more slippery than normal, I've encountered no issues. So, I do see it as an all-season tire but with caveats.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#36 | |
yea i just got them on a few weeks ago and it said it was suppose to rain at the track all weekend so i was a bit hesitant had a wet drive otw to the track but just sprinkled a bit during the day so no problems but started pouring around 4pm and i ended up leaving early
#37 | |
Matt Miller
2020 SS 1LE |
#38 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
#39 |
na fontana aka autoclub speeday went last month in 100 degree weather on ps4s i did a 1:59 added spl toerods and goodyear supercar3 and it was 50 degree cooler and i did a 1:53 but most of day was 1:55 - 1:56
#40 | |
#41 |
haha yup i agree just trying to figure out what i want to spend my next bonus on
camber plates new brake pads rear solid bushing kit hmm lol still want a set of recaro 1le/zl1 seats but can never find a set local to me!
#42 | |
