#29 |
They are not going to hook as well as a MT at the track.
#30 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#31 |
![]() Drives: A Vette Join Date: Jan 2020
Since this thread is still going on I figured maybe I ask how does the Nitto 555r2 compare to the Toyo r888r? Anyone ever tired these two and have a preference as to which they like better and why? I believe the downside to the Toyo r888r is that there a bit pricey and people have mentioned they have quite a bit of road noise (not sure how bad the road noise is). I’m curious to know how they are in the rain, how long they last, or how well they put the power down compared to the Nittos but something tells me that the Nittos are the better well rounded dual purpose drag radial tire as Z OH 6 has mentioned.
#32 | |
![]() ![]() Drives: 2019 2SS Camaro Join Date: Apr 2012
#33 |
LIL SLOW SS
Drives: 2017 SS Join Date: Jul 2020
What’s the best PSI to run on this tire to get optimal traction?
I know my 555R1s liked 23psi. I’m running the same 23psi on my RIIs and spin a lot. I went from a 305/35/20 555R to a 305/45/17 RII and so far the R1s hook better from a 1st gear roll. Any feedback will be appreciated. I’m going to try 20 psi |
#34 |
![]() Drives: 2019 camaro 2ss Join Date: Feb 2020
I’m running them in 305s, hooks better than my ps4s that I had before this! I can deadhook a 40 roll, and maybe even a 30 roll once the weather heats up. They’re tolerable in the rain, just take it easy. And don’t do snow!
Edit: this is all on the street, can’t speak about the track
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
#35 | |
#36 | |
#37 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Glad to see the Nittos are back in stock now...been waiting nearly 6 weeks. Just ordered a pair of 555r2 to go with my G2s up front. Unfortunately still waiting on Weld Racing to get me the wheels. They pushed my date from next week to end of March :(
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#38 |
#39 |
Intriguing, I'll keep this in mind. Thanks for the info
#40 |
![]() Drives: 2020 LT1 Camaro Join Date: Oct 2020
I use the G2 in 295 40 18 for winter tires. Put them on last October and went 1 last time to 1/8 mile track on a low 40 degree day. Did smoky white devil burnout and they actually dead hooked off the line. Ran a 7.65 pass. Ran a couple of 7.7 passes with a passenger same day. Went to track this past Saturday, did a smoky burnout(same tires) left on third yellow and tires went up in smoke all over the track. Nothing could be done in the warmer weather 80 plus degrees to make them stick. They just got greasy. When I got home I put on the 555r2 in size 285/40/18 on 10inch wide rims and also installed lower trailing arms. Had plans to do that before TNT but work and weather prevented. Next TNT i can get to is on the 27th this month but already can tell they are gripping better than the g2.
