Old 05-19-2020, 11:24 AM   #29
minn19
minn19's Avatar
Drives: 22 ZL1, 20 Taco, 20 Cayenne S
Originally Posted by 69pro-touring View Post
This is all news to me. I've always just used a HF low-profile jack and an amazon magnetic pinch weld puck to jack one side at a time. Even if I place it at the front most jack point it still lifts the rear up before you could get a jack under it. Never had any issues before, now I'm going to be worrying every time I swap wheels.
Same here and done it a few times now, no problems.
minn19 is offline   Reply With Quote
Old 10-31-2024, 09:53 PM   #30
JaslynSchmitt
Drives: BMW
I’ve lifted my car from the pinch weld a few times and haven’t noticed any issues with quarter panel creases. Just make sure to use a proper jack and support it well. It's always good to double-check everything after lifting to catch any potential problems early.
JaslynSchmitt is offline   Reply With Quote
Old 10-31-2024, 10:00 PM   #31
roymitchell
roymitchell's Avatar
Drives: Toyota Corolla
I know it's been a while, but I get your concern about lifting from the pinch welds and causing those quarter panel creases. It can be a real headache. I’ve seen it happen before, and it’s not pretty. Try using a scissor lift instead of a regular jack or lift if you can. It spreads the weight more evenly, which helps avoid those annoying creases. Just make sure you place the lift pads in the right spots. Always double-check the owner's manual for any specific lifting points.If you’re worried, putting a piece of wood or rubber between the lift and the pinch weld can help, too. It adds a little cushion and gives you peace of mind.
roymitchell is offline   Reply With Quote
Old 10-31-2024, 10:50 PM   #32
Old 11-01-2024, 04:38 AM   #33
Owl3
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1
Mine sat on jackstands located at those jacking points for over 3-1/2 years with no issue
Finally on the way to 1K.....
Owl3 is offline   Reply With Quote
Old 11-01-2024, 06:58 AM   #34
Don't get fooled by AI trolls, guys
Old 11-01-2024, 08:54 AM   #35
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
You have seen quarter panel creases just from jacking the pinch weld alone?
Or are you talking about what can happen if the jack slips?
The only place I have jacked my car so far is the pinch welds and differential. I use home made jack pucks. Haven't had any concerns yet.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 11-01-2024, 10:14 AM   #36
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
What he said!
I think this is the first time I've seen one AI respond to another AI though! They must be getting smarter. It's not Skynet yet, thank goodness.
Mods being installed-
