Old 10-27-2024, 08:56 AM   #29
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
However, they still have the same crappy lifters... They just aren't being "activated"...
Exactly.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is online now   Reply With Quote
Old 10-29-2024, 06:35 PM   #30
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
Got mine today... a winner!
Better throttle response using all eight cylinders all the time. Slightly more engine/exhaust sound at low speed and a need to ease up to avoid tire spin. It may cost me a little more gas but sure worth it.
cgdelena is offline   Reply With Quote
Old 10-29-2024, 07:13 PM   #31
SSShark
SSShark's Avatar
Old 10-30-2024, 06:07 PM   #32
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
Asked this once before, don't recall getting a direct answer, so I'll shoot again
Is a Range useful/helpful on a v6 1/2/3LT Camaro?
Anjilslaire is offline   Reply With Quote
Old 10-30-2024, 06:40 PM   #33
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
Depending on how you define useful I’d say that it is.
If you want full access to your full power at all times and want
to eliminate wear and tear on your lifters it’s definitely worth it.
RIPws6 is offline   Reply With Quote
Old 10-31-2024, 06:11 PM   #34
Anjilslaire
this is what I was looking for. Just wasn't sure if it was helpful on the LGX, thanks
Old 10-31-2024, 08:14 PM   #35
RIPws6
RIPws6's Avatar
Anytime. I think you’ll love it when you go up your first hill and you don’t hear the engine trying to steal back the power from AFM mode. It drove me nuts.
From a V8 or V6 standpoint, you don’t upgrade your exhaust just to have it sound like a Ford Pinto after you reach cruising speed.
I MIGHT have kept the stock exhaust if I had bought the Range sooner.
Old 10-31-2024, 08:32 PM   #36
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
The lt1 valvetrain is way different than the lgx. 4 cams over the valves vs 1 cam pushing sticks. I don't know that lgx has afm problems.
Gen6cyl is offline   Reply With Quote
Old 11-01-2024, 09:33 AM   #37
MisterMarauder
MisterMarauder's Avatar
Drives: 2023 Radiant Red ZL1
Also, for what it's worth, the LT4 in the ZL1 has the AFM tuned out from the factory.
Current
1992 Z28
Previous
2018 2SS Redline Edition
1992 RS
MisterMarauder is offline   Reply With Quote
Old 11-01-2024, 09:44 AM   #38
SSShark
SSShark's Avatar
Thank you mistermarauder! That's exactly the point that I've been trying to get across. Either tuned out or with the range, it's the same result. The internals are still there but same result.
Old 06-29-2025, 04:54 PM   #39
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
So, has anyone had a Range until fail on them? I was heading to our Camaro Club Car Show yesterday and was flipping through the screens and noticed my car as in V4 mode! Initially, I thought perhaps the BCM update disabled something in the OBD port that was preventing the Range unit from working any longer... Gothome and sure enough, none of the light on the Range unit were working with the ignition on or off... Unit was just about 5 years old...
Ordered a new one on Amazon and took it for a test drive today, stayed in V8 mode the whole time so fortunately it was just a failed Range unit...
2SS Capt is online now   Reply With Quote
Old 06-29-2025, 07:21 PM   #40
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Its pretty easy to turn it off in the tune with hp tuners.
I could see the VLOM solenoid eventually failing and letting pressure bleed into the lifters. It will more than likely be misdiagnosed as a lifter failure and the entire cam and lifters will be swapped out.
Watch videos on cutting vlom seals. If anything you can understand how it works in more detail. If the lifters can never have oil pressure on the top of them then they wont unlock. There are mountains of information on the subject but unfortunately there is just as much misinformation. I was sitting just short of 260k on my silverado that had DoD with the stock lifters, with no lifter failures.
bishopts is online now   Reply With Quote
Old 06-29-2025, 08:12 PM   #41
2SS Capt
2SS Capt's Avatar
Nice, but my comment was regarding the Range AFM Disable device failing (stop working and therefore letting the car go into V4 Mode)...
I ended up buying a new Range AFM Disabler and am back to V8 only mode, but was just surprised that the 5 year old Range unit failed...
Old 06-29-2025, 08:18 PM   #42
bishopts
bishopts's Avatar
Maybe it's made in China since radioshack is out of the question.
Where does it plug in?
