#29 | |
![]() Drives: 1968 Camaro and 2019 ZL1 Join Date: May 2019
#30 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
First run was a 2.0 with some spinning but I babied it off the line. I wasn’t able to do a burnout bc I forgot how to use line lock. Got frustrated and just rolled to the beams. Left with little preload at 900rpm and 1/4 throttle the first 100ft then pinched it. Ran 11.1 at 137mph.
Second run I have no idea as it broke |
#31 |
Quick update. It was not the drive shaft.
Broke the right side axle. |
#32 |
Moderator
Going with GForce Outlaws?
#33 |
#34 |
![]() Drives: A10 ZL1 Join Date: Mar 2018
You don’t have to burnout for the whole 15 seconds line Lock is initiated. Just light em up a little it and let the timer run down.
#35 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Agreed. When I see smoke I call it
#36 |
Lol! Yea 15seconds would be bad. My burnout was 6seconds bc I was trying to get line lock disengaged to roll forward but it wouldn’t. I much rather prefer a 3 second burnout.
#37 |
I have the DSS and happy with them. You saved yourself a bunch of labor time but the axles are more then the DS.
#38 |
Yea the axles are 2x more than the DS. I just found out there is a 4 week build time. I have not taken the axle off so I’m still not clear on the damage. Was wondering if it was a fluke and the ZL1 axles are in fact strong but maybe I ended up with a dud? I don’t want to rush things but don’t want to be out of the game too long either.
#39 |
![]() Drives: ZL1 1LE Join Date: Oct 2018
There’s a set of DSS for sale in the classifieds: https://www.camaro6.com/forums/showthread.php?t=571266
#40 | |
#41 |
So broke 4 teeth off the axle and blew out the bearings from the CV joint.
#42 |
Whew, screwed that one didn't ya. Dam
