Old 01-28-2020, 08:32 AM   #29
laynlo15
Drives: 2022 Lt1 A10
The SS kit comes with the 98 not the Zl1
Old 01-28-2020, 11:09 AM   #30
L78toLT1
L78toLT1's Avatar
Originally Posted by XXX ZL1 View Post
Gen 6 lt1 kit and the ZL1 kit is different kits. The ZL1 comes with 80mm pulley.
Ok. Good info, I didn't know this.
Baby Blue
Old 01-28-2020, 11:29 AM   #31
staples87
Drives: 2017 Camaro ZL1
I'm thinking this may be the route I'd like to go. Of course I'd love the chop of a cam, however at the price point, to me anything over 700whp is going to be tough to hook on the street, especially on a 305 (reg ZL1). I rather just fill up with 93 and go. Not deal with E-85 mixtures or methanol. Could you let us know the type of Intake air temperatures you're seeing at 12psi on the 2300? I'd like to compare it to stock 1.7 that is a mobile oven lol.
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 01-28-2020, 11:55 AM   #32
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
The last dyno pull the air temp only rose 9 degrees if I remember correctly. It recovers very fast as well. The next day I did another ZL1 with porter blower, 15 lbs, and direct port meth with 44 gph worth of nozzle and it rose 20 degrees during the pull. My car is a riot to drive. Even my 325 cup 2’s are up in smoke pretty easy. Lol. Like you I wanted to just run pump 93, no meth, no mixing, no heat issues.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 01-28-2020, 04:58 PM   #33
cirpower
Drives: Camaro ZL1
Awesome information, thanks for keeping us posted!
How was the fit and finish of the kit? I am considering this kit, but only if I can fit in my garage as an amateur mechanic. Is everything you need included?
cheers
cirpower
cirpower is offline   Reply With Quote
Old 01-28-2020, 11:54 PM   #34
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Finally put the car on the dyno to get a baseline. I’m running a Maggy 2300, 3.15 upper pulley (stock 80mm is 3.2), 2 inch ARH full system, 103 inlet, and rotofab big gulp. Setup made 12 lbs on the dyno. Car made 703 rwhp and 709 rwtq on 93 and NO meth. Fueling looks good here and I will work on timing tables on the street/track. Car will take another 3 degrees easy, but with the fuel limitation of the stock cam I want to inch timing in and watch fuel pressure. Air/fuel was half point rich also, but I’ll clean that up when I get on the street and can watch pressure.
Air temp and MAT temps is where this thing shines. Temps are much more manageable over stock blower. Very minor climb during the dyno pull and recovers well, something the stock blower doesn’t do well on the dyno.
I think the car will make 740 rwhp range with fueling and timing cleaned up. As long as stock fuel system allows it. Lol. With the pulley it’s running I’m not even scratching the surface of what this blower is capable of. Plenty of room to grow!
What numbers were you getting on the dyno before these mods?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 01-29-2020, 07:05 AM   #35
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
cheers
cirpower
Install is very easy on these cars. Kit is very nice and complete. If you get one and have any questions just hit me up, be happy to help.
Old 01-29-2020, 07:23 AM   #36
FoundNemo
Drives: 2019 ZL1
I'm assuming the Maggie 2300 doesnt come with a tune right? Did you go Jannetty or? I dont think I would need a Voltage Booster for just a 2300 swap but I would want to make sure the tuner was reputable and that they werent going to turn off the Cat Overtemp etc.
FoundNemo is offline   Reply With Quote
Old 01-29-2020, 07:26 AM   #37
L78toLT1
L78toLT1's Avatar
I highly recommend Ted Jannetty. He was great to work with on my build.
Baby Blue
Old 01-29-2020, 07:29 AM   #38
Depends on which one he bought, there is a full version that comes with a canned tune and a cheaper tuner version that doesn't.
Old 01-29-2020, 07:55 AM   #39
SlikZL1
Drives: 2019 Camaro ZL1
XXXZL1 is THE guy when it comes to tuning. He is the person some of these big shops call to ask questions lol. And the voltage booster, we are going to start running these to help stabilize low side fuel pressure. JRE uses one on every build and they are pretty strait forward. Installing mine this weekend
SlikZL1 is offline   Reply With Quote
Old 01-29-2020, 08:00 AM   #40
FoundNemo
Drives: 2019 ZL1
Good to know!
Old 01-29-2020, 08:59 AM   #41
cirpower
Drives: Camaro ZL1
Great, thanks!!!
Old 01-29-2020, 10:10 AM   #42
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Ted is top notch all around! I tune for a living so that was the easy part for me. Lol. You won’t need any fuel mods if only doing the 2300. If your planning on going over 670-680 rwhp the JMS voltage booster is a really nice piece to clean up low side fuel pressure.
