Old 01-15-2020, 01:31 PM   #29
Krowser
Krowser's Avatar
Drives: ZL1 Mosaic Black
Originally Posted by Badmojo View Post
You do realize that a 5W30 has a higher viscosity at cold temps than a 0W40 right?
Yes.
I live in south Florida, so my average cold temperature is 75-80 degrees.
The 0w is for 0 degree weather and Mobil 1 has engineered packages and additives into the oil to provide oil flow at or greater than 0 degrees. IMO, you want oil to flow and get to all sections as quickly as possible. Once you start the car AND GET THE OIL TO OPERATING TEMP, the 5w and 0w means absolutely nothing.
My biggest reason for putting 0w 40 into my ZL1 is i occasionally do freeway pulls and/or spirited driving. LT1, lt4 and lt5 engines that are pushrods motors driven between 4800 - 6800 rpm, IMO, require steady lubrication due to the large mass of their rocker assemblies and rotating parts.
If you ever have a chance to watch cars live on a time course at homestead speedway or any other track with ovals and straightaways, you'll hear how the motors have to sustain high rpms for 8 - 10 seconds at a tiime.
THERE IS NO WAY IN HELL 5W 30 CAN TAKE THAT BEATING!!!...that was my point
Krowser is offline   Reply With Quote
Old 01-15-2020, 07:37 PM   #30
Badmojo
aka BeastZL1
Badmojo's Avatar
It is the correct choice. A 0W-40 doesn't require a warm-up period on start-up and I agree is mandatory if you are running 280+ F oil temps on track.
Originally Posted by Krowser View Post
Yes.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 01-15-2020, 10:10 PM   #31
Pupilbone
Pupilbone's Avatar
Drives: 2019 Crush ZL1 M6
Originally Posted by ZL1 1LE View Post
5W30 was replaced with 0W40 in 2019. I made the switch and replaced the oil cap. 0W40 can be used on the street and the track for the ZL1s. ZLEs have to switch to 15W50 for the track.
Can someone please explain to me why I see so many state ZLEs and ZL1s as having different oil requirements on the track? No difference at all in motor right?!
#SaveTheManuals
Pupilbone is offline   Reply With Quote
Old 01-15-2020, 10:38 PM   #32
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Actually with Mobil1 the 0w40 is higher viscosity at lower published temp (40C) than 5w30. The second number has more overall bearing on total viscosity than the first.
Refs:
https://mobiloil.com/en/motor-oils/m...il-1-esp#5W-30
https://mobiloil.com/en/motor-oils/m.../mobil-1#5W-30
Old 01-16-2020, 04:09 AM   #33
waterman
waterman's Avatar
Drives: Grandad's C2 L89
https://www.camaro6.com/forums/showthread.php?t=535476
2018 ZL1 1LE sw/PDR
Old 01-16-2020, 05:48 AM   #34
waterman
waterman's Avatar
I thought that it was the placebo effect.
2018 ZL1 1LE sw/PDR
Old 01-16-2020, 07:28 PM   #35
It all started with Corvette and trickled down to Camaro.
ZR1 and ZLE pull more G-forces on track so have a different requirement. 0W40 for all other occasions.
mlee is online now   Reply With Quote
Old 01-16-2020, 09:09 PM   #36
Badmojo
aka BeastZL1
Badmojo's Avatar
I'm not sure who considers 40 C (104 F) cold temp. The bottom line is one of the posters saying you need to warm up your car with 0W40 for 2 minutes is garbage.
Refs:
2019 Camaro ZL1 1LE
