#29 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
My car has the manual trans.
#30 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Just got mine today, ordered on Wednesday. Installed in about 10 minutes "already had the other off the car". Pulled the negative battery cable so it can go through the "relearn" phase at the next startup in 8 hrs, according to instructions. Will post results tomorrow, hopefully.
#31 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Good to have more than one guy coming from a TM.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#32 |
![]() ![]() ![]() Drives: ZL1 1LE A10 Join Date: Mar 2015
EDIT: For those reading this later... A few days after this post, my issues resolved themselves. Soler TB appears to be the real deal.
Well... Not the experience I was hoping for... For starters, I'm used to seeing a little gray tab on the connector that plugs into the OEM TB. My 2018 ZLE M6 had it and I pulled the TB on and off at least a half dozen times. Same for my 2017 Z06. This car didn't have the tab. So I pulled the TB off with the connector still attached and took a closer look and it was snapped off -- awesome job by whomever assembled that at the factory. So I had to pull the connector lock mechanism out with a pair of needle nose pliers and will be needing a replacement connector. **SIGH** So I'm grumpy. GRR. I put the Soler TB on and DID NOT follow proper learning procedure. (Please refer to the part about being grumpy). I found the Soler TB to be very wonky at first. There isn't a bog anymore but now there's a delay... I eased into a few normal speed stop and go's and got up to highway speeds for a bit, attempting to let the computer do some learning (again I didn't follow the learn instructions). For a bit the delay seemed gone but then it came back again, and then gone. There is no sign of any bogging. Only an intermittent delay. SO. In the spirit of science. I tried various settings, manual shifting mode, auto shifting mode, touring, sport, track, traction control on and off. The feeling I'm getting is that the delay is as follows: In Manual Shifting mode there is no delay, with traction control off it will spin the tires from a stop with a sudden 1/3 throttle press (discovered entirely by accident). In Auto Shifting mode Sometimes there is a delay and sometimes there isn't. When there is no delay everything feels great. No complaints. When there is a delay: - When driving it feels like the car takes longer to realize it needs to downshift. - From a stop, it feels like the car does nothing for a 1/4 second. In fact when it happens my head thrusts forward to counter the anticipated forward momentum but there isnt any so I just look silly. - Touring and Sport are more pronounced - Track is less pronounced - Traction control makes no difference. So I will let the car learn more. I might even try starting over and following the exact procedure. But even if it does not improve (not saying thats the case -- just worst case scenario) I think people with a M6 will be fine. I think for me, so far, this is a case of a confused A10 (hopefully temporarily confused). PS - I don't think the connector has anything to do with it. Even though it's not locked into place and can come lose over time, I checked it and it is firmly in place (for now).
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 Last edited by angryBits; 06-26-2019 at 05:57 PM. |
#33 | |
![]() Drives: 2018 Camaro ZL1, 2017 Z06/Z07 Join Date: Jan 2019
___________________________________________
2018 ZL1, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, ATI Underdrive Pulley 673/688, 2017 Z06/Z07, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, IW 18% Underdrive Pulley 640/664, 2019 Mustang GT Perf Pkg. 1 |
#34 |
Drives: 2018 SS Join Date: Jun 2018
Posts like this suck for people buying and selling aftermarket parts. You just wrote a book about changing a throttle body, did not give the computer a chance to learn about your important airflow changes, and then complained about the way it felt afterwords. If you are not going to follow proper instruction then save your comments until you do so you have an educated opinion rather than a "grumpy" half assed one. People who don't know a bunch about cars and are looking to buy this mod may not after reading stuff like this.
Mike@SolerPerformanceLLC I like the work you are doing here and it is refreshing to see someone spending the time to figure out porting in the way you are. Most of it is a bit above my head, but I appreciate the difference rather than a dude with a dremel and some epoxy reporting a stock TB. This is on my short list of things to buy for my car for sure. |
#35 |
![]() Drives: 2015 Corvette Stingray Join Date: May 2019
Angrybits, give it a few miles/cycles, especially if you did not reset the ECM. You might want to secure the connector with something else, as it may feel secure but engine vibrations are significant.
Note: There are built-in delays in automatic cars that the TB can't do anything about. I.e. when decelerating substantially or coming to a stop and then accelerating, there are from .25-.75 seconds of zero torque commanded by the ECM to allow tranny to shift.
Tiffany,
Soler Performance LLC, support@solerengineering.com www.solerengineering.com (251) 468-9786 |
#36 | |
![]() Drives: '18 RH ZL1 1LE Join Date: Apr 2018
This is the same as the idiots on Amazon who give one star reviews because of damaged shipping, or they bought an incompatible part, or didn't follow directions. Completely useless and a distraction. Last edited by full*throttle*therapy; 06-23-2019 at 09:55 AM. |
#37 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Awesome thread over on c7. Learning a lot.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#38 | |
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
#39 | |
Apologies for the drama. I was not expecting these kinds of replies. I thought I was clear about it being automatic specific and that I didn't do proper learning.
#40 |
Yes I hate those too. I apologise. I was just sharing my experience. It might be useful for someone that was lazy and did not follow procedure like me.
#41 |
Loves Camaros
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert Join Date: Sep 2012
![]() I'm interested! This would be my first mod, so I'm considering carefully. Tara
Old and new, sharing space!
#42 |
Just got back from my "learning phase".
Step 2 - Completed without any issue. Although it had a rough idle at the startup, but went away quickly. Step 3/4 - Partially completed. Prior to the start of the relearn, I contacted Mike about this step, my concern was having my neighbors complain about the noise at 4000 RPMs. I have an AWE Track Exhaust and it is a "little" loud. Nevertheless, on my first acceleration, it would not go beyond 2500 RPMs, so I figured it was still learning. So I went back down to idle, left the car run for a few more minutes. The second acceleration went to 3000 RPMs and no further. I had no codes, so I felt comfortable the TB was relearning. Turned the car off. Step 5 - Started the car, without any issue. Although it doesn't specifically say, I think this step is more for A10 than M6. But nevertheless I went though the gears and had no issues. Step 6 - Started the car, without any issue. Time for a drive, to give the TB an opportunity to graduate from elementary school. Weather - Sunshine, mid 80s, little humidity. Car was in Touring Mode "as recommended in the instructions", Rev Match on Speeds varied between 25 and 70 on, In-Town, country and 4 lane divided highway roads. About half the trip the Cruise Control was active. Total of 132 miles at an average speed of 48 MPH and a 21.9 MPG During the trip, I had about 12 occasions, in which I attempted to stale the car from a dead stop, i.e., stop light, stop sign, etc. Something I was having a problem with, for both the OEM TB and TM TB. Needless to say, I couldn't. Although I don't think I did anything different, it would be difficult for me to say it was all the TB! Additionally I had on 5 occasions to test the response of the TB at, shall we say "spirited driving". It was responsive, crisp and clean and didn't have any "bog" events that I was aware of. BTW, the last thing I did, before I turned the car off in the garage was take it to 4000RPMs. Had no issues! Overall, I am very pleased with the Soler TB. Mike has been very responsive to my questions and answered all my concerns quickly. Thanks Mike for the great customer service and an even better TB. If anyone has any questions, please let me know and I will try and answer them. I am going to continue to drive the car for the next couple of days, because I am taking it to the track on Thursday at Dominion Raceway. I will post my observations about the TB during that event. |
