#29 | ||
Wash your car in the coolest part of the day, in the shade, which at this time of year is the morning, at dawn.
Perform a pooling rinse after rinsing all the soap off, which will greatly minimize the amount of water left on the car. If you have any water spots, use UWW plus concentrate and do a wipe down with gentle pressure. It's inexpensive, and works great.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
#30 | |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
I wash at the coin wash, spotless rinse, then do a Garry Dean wash and dry in the detailing area there. No hard water spots...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 05-01-2019 at 10:21 PM. |
#31 |
![]() Drives: 2018 Camaro ZL1 A10 HBM Join Date: Mar 2019
Thanks for all the info everyone! I've learned a lot from reading your responses, linked threads, and watching the videos. I'm sure I'll settle into my own method over the next few months.
Garage Baby 1: 2018 Camaro ZL1 A10 HBM w/Rotofab CAI, Tony Mamo Ported TB, AWE Touring Non-Resonated Exhaust, Diode Dynamics Sidemarkers, Suntek PPF, Feynlab Ceramic Coating Garage Baby 2: 2017 Dodge Challenger R/T Scat Pack 392 Shaker A8 Green Go |
#32 |
![]() Drives: 2018 SS 1LE Join Date: Aug 2018
I bought one of those smaller in-line water softeners and use it in-line with my pressure washer, in an attempt to stop washing the car with such hard water. It almost works for one enitre wash, then I have to recharge it because the water coming out measures hard again. I have a water softener system for our house but the outside spickets are bypassed. I have a utility sink in the laundry room that is softened and leads directly to the garage. Trying to figure out a way to run that hose from the utility sink, through the door to the garage, then to my pressure washer?!? Would like to be able to close and open the door while washing as needed, and any type of hole in the door will need to be able to be plugged when not being used?!? Toyed with the idea of removing the deadbolt in the door when I wash and running the hose through that hole.
#33 |
![]() Drives: 2018 Camaro SS Join Date: Sep 2009
I bought this little guy to blow water off after a wash. It has a great power to price ratio. I doubt it works as good as a $400 piece but at $32 it’s hard to beat
Sun Joe SBJ601E 10 Amp 215 Max MPH All-Purpose 2-Speed Electric Blower, Green, Green https://www.amazon.com/dp/B01BJ2YRPQ..._5xd3CbJ0QFNRV |
