Old 02-23-2019, 07:10 AM   #29
laynlo15
Drives: 2022 Lt1 A10
Mark from Magnuson set up a base E85 tune for me and I'll pick up some E85 today which I believe is only E70 right now, then tomorrow after I burn a little more Vp out I'll switch it over and do a little more driving. I know my sensor is active as it says I have 0 percent E in it. I only have a month or so to get ready to head to Atlanta for the Eaton TVS Throwdown and its a 11 hour tow so I have to have all my ducks in a row before I leave including at least 1 TNT. My car won't pass tech for anything quicker then 10.00 so I'm going balls deep at TNT and then back off a pulley size to slow it down to run True Street and Bracket Race, plus I'll still enter the Throwdown for fun.
Old 02-23-2019, 08:04 AM   #30
L78toLT1
L78toLT1's Avatar
E85 is plentiful and cheap in the Atlanta area. If I have adequate enough fuel supply once I add lt4 fueling and a cam, my car will never again taste 93 octane. If I can't run full E85, then my next mod will be a lingenfelter hpf p...really hope the lt4 stuff will get me there
Baby Blue
Old 02-23-2019, 09:15 AM   #31
laynlo15
How's your build going? I might take fuel with me, but if Commerce, Ga has E I may just save weight of not hauling 15 gallon extra and just buy it there.
Old 02-23-2019, 07:09 PM   #32
Drsagacity
Drsagacity's Avatar
Depending on how much boost you throw at it, the Lingenfelter pump may do no good. I ran out of injector before my hpfp gave up. Now, maybe if I lowered the %e, then the hpfp would be next...but won’t know until summer. Just an FYI.
I never took my car to the dyno with the final tune on 10psi. I might go ahead and do that for my winter fun...that way I have a dyno on 8, 10 and 12.
It was 715 @8psi and 776 @12 psi...but truthfully, I think I had some slippage on the 12 psi run.
I ran those two on the same dyno the same day. I was thinking that my 10psi pulley would be right in the middle...but as I have sat around all winter with nothing to do...I realized that if I had slippage at 12psi...that might not be true.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 02-23-2019, 09:32 PM   #33
laynlo15
I'm going to run the 70mm next weekend and then the 75mm to how much power is lost between the two. I may as you did run out of injector on the 70mm. I'd like to consistently run E65 to E70 plus I'll spray some Meth also. I don't know how much I can make but what ever it is it will be safer and more then last year. I just want to keep the boost below 13 lbs. I'm also willing to do a little VP mixing if needed to make sure I don't have an issue with fueling. Not spending anymore bucks this year, however it turns out is what I'm running.
Old 02-23-2019, 10:21 PM   #34
Drsagacity
Drsagacity's Avatar
I think that with alky injection you won’t be leaning on the injectors so much so that you should be fine. I don’t recall who, but someone else with a similar setup was running in the 830whp range by using alky injection to supplement e85. Based on what I saw in the logs, that’s exactly where I was before my injectors we’re out of room.
Truthfully, I would love to add the FIC injectors to see what it would look like. To me, that would be infinitely better than relying on alky injection.
Btw - I went back to the 80mm for the street...it looks like that is 10-11psi now. Maybe we should go hit the dyno together and see how the rides stack up. Let me know when you are going. Ted and I are planning a tune on VP109 that would only be a track tune...then on the street I will run e and 8-12 psi.
TBD performance
Old 02-24-2019, 09:39 AM   #35
L78toLT1
L78toLT1's Avatar
I'm still a couple of weeks away from firing up the car for the first time in what seems like months! The machine finished my motor last friday; I'm picking it up sometime this week and hope to start assembling next weekend.
I imagine E85 will be readily available in Commerce, but cannot say for sure.
Baby Blue
Old 02-24-2019, 11:09 AM   #36
laynlo15
Hopefully testing next month will be successful and I'll be ready to compete again this year. I missed the last 3 months of the season last year by not getting my shit together soon enough. I'm not pushing this engine to the hilt like I did the stock engine. I still have a few weak links in the drive train and hopefully they'll hold up for a while.
