#29 |
![]() Drives: 2018 ZL1 1LE Join Date: Sep 2013
Correct, the sub strap goes between the seat cushion & the backrest where they're split and you basically sit on the sub strap. Although this is not a perfect solution like a race seat, it is the only option to retain the factory seats, all air-bag functions, and safer than without. Good luck if you go this route!
#30 | |
![]() Drives: 2018 ZL1 Join Date: Jul 2017
Mark
Mark E.
2018 ZL1 NGM A10 87 Grand National. Modified Hot Rod for sale *SOLD* 87 Grand National. Stock 65 Olds Vista Cruiser wagon Grand National motor/tran 66 Bronco Rockbuggy 2006 Dodge 2500 4x4 Cummins 6 speed |
#31 |
Left Lane Enforcer
Drives: '18 ZL1 1LE. Join Date: Jul 2016
I'm very curious to the safety of a bolt in cage like this in an accident. those are some tiny looking bolts. I have also gotten mixed reviews on bolt in cages...m
Current Cars:
2018 Camaro ZL1 1LE 2012 Ford Focus SE 1994 Evo II Previous Cars: 2017 Camaro SS 2014 Chevy Malibu LTZ |
#32 | |
![]() Drives: 2018 ZL1 1LE Join Date: Oct 2018
Some of the most important design factors that must be considered in a bolt in cage vs weld in cage are: 1) Hardware Grade 2) Base Plate / Backing Plate Design Please see the excerpt below from SCCA rulebook regarding bolt in cage fabrication: https://flic.kr/p/2dVpPn3 In the case of our cages, we go above the minimum required bolt grade, and employ the use of Grade 8 hardware for all of our mounting locations. For base plate design, we ensure that we meet the thickness and size requirements in the rulebook, as well as incorporate the use of oversized backing plates for each mounting location to help further disperse load in the event of a rollover. |
#33 |
![]() Drives: 2018 ZL1 1LE Join Date: Dec 2016
DLCT3, If you don't mind me asking (and I hope I didn't miss it somewhere), what was your out-the-door cost?
#34 |
#35 |
![]() Drives: 2018 ss Join Date: Jan 2018
I’d be interested in pricing also I’m in Raleigh area
Sent from my iPhone using Tapatalk |
#36 | |
However, I think my total cost minus the Hans was probably around $4200ish. I took advantage of some black Friday sales so that helped, but really overall for everything it includes its a cheap mod for the safety aspect & extra protection. Heck a set of quality wheels and tires cost more than that!! Last edited by dlct3; 01-04-2019 at 08:22 PM. |
#37 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Aug 2018
A nice setup. Exactly what I've been thinking form my zl1 1le. You mentioned this is a custom job by G. Therapy. Did you have to supply measurements, preferred attachment locations / methods, etc? Or are they already jigged up to get just the right fit specifically for the 2018 ZL1 1LE? I talked to bkauto a while back and discovered there is a 4" difference in the 'between-the-seatbelt' mounts in the rear when compared to other Camaro models. Makes me wonder about other dimensional differences one might discover.
Are you going to leave it as bolt-in or maybe weld it in later? Do you have phone no. for the guys at Garage Therapy? |
#38 | |
We built this roll bar in our own personal zl1 1le's and then jigged it up for production. We have sold the bar to a customer with an SS, and it was the exact same dimensionally, so we did not note any measurement differences between the SS and the ZL1 1LE. Even though this is jigged for production, we can customize it to suit your needs. If you send your car to us, we can do a weld in install, if it is preferred for your application. However, the bolt-in solution we offer does meet the SCCA requirements and can be used for track days. |
#39 |
The way mine bolts in with the backing plates on the outside makes it part of the car. I'm not saying it will take a 180 crash but I believe I have a better chance at 140 plus then I do without. So I feel much better having it. Rpm is NHRA approved on their Chromoly 6 pt. down to 9.99. If I go quicker then that its on me. The backing plate really tie it all together so I'm fine with what I put in my car.
#40 | |
#41 |
![]() Drives: 2017 Camaro 1LE Join Date: Oct 2016
RPM
6 point RPM install and just waiting on Sparco EVO seats to come in.
#42 |
I have the same as Jsspeed, but mines not notched into the bulk head.
