Old 11-20-2018, 07:00 PM   #29
aai
aai's Avatar
Drives: '17 SS/1LE/PDR
Originally Posted by MAGAUSA View Post
I agree! If I'm gonna blow my warranty, I may as well do it right.
pushrod V8? gotta love it. Heres the thing, seems to be there's an unwritten rule of posting cam cards, I never see any, out of respect for our vendors? I never ever see them post full specs either. I don't know man. My intentions are good...but
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
aai is offline   Reply With Quote
Old 11-22-2018, 12:27 AM   #30
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Most of the vendors now publish their basic cam specs. Talk to cam motion they have a very big selection of gen v cams. Everybody else has 3 or 5 cams tsp, Lingenfelter, btr, katech, mti,livernois hell comp only has dod cams. Cam motion has truck cams turbo cams suoercharcher cams both dp and centri so I would highly recommend talking with them and have them help yiu select a cam
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 11-29-2018, 11:13 AM   #31
18ss376
Drives: Camaro
Lingenfelter GT30 cam with CNC ported heads and long tube headers makes right around 570hp.
18ss376 is offline   Reply With Quote
Old 11-29-2018, 12:13 PM   #32
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
at the crank right?
that would be a lot I would think at the wheels,
when I get around to cam and head I'm looking to do stock ported and hope to be like 480 at the wheels that's my hope anyway..
biker2k is offline   Reply With Quote
Old 11-29-2018, 12:24 PM   #33
18ss376
Drives: Camaro
Yes FWHP is what they told me.
Old 11-29-2018, 02:30 PM   #34
6spdhyperblue
Drives: 2SS 1LE
Aren’t those smooth idle cams really soft down low and rev happy tho?
Old 11-29-2018, 08:52 PM   #35
oldman
Drives: SS 6 speed of course
Drives like stock or idle likes stock? They are not one and the same. A 110 lobe center cam will dive like stock, in fact better than stock, with a strong and responsive mid range. But it lope at idle. A 121 LSA, NA / blower general performance cam with smooth idle say 220 / 230 duration is gonna be pretty smooth, but will not have strong mid rance and part throttle tip in.
Old 11-29-2018, 09:07 PM   #36
6spdhyperblue
Drives: 2SS 1LE
Yup exactly, talking about the second one with the large split and high lsa
Aka gt30 cam
Old 11-29-2018, 09:13 PM   #37
oldman
Aka gt30 cam
https://www.lingenfelter.com/product...l#.XACcWvZFzb0
DOD/AFM Compatible
DOD Lobes: intake/exhaust
Duration @ .050 valve lift 219 / 231 Lift with 1.8 rocker .576 .576 LSA 116
Non DOD Lobes: intake/exhaust
Duration @ .050 valve lift 217 / 229
Lingenfelter GT30 Camshaft GM Gen V Engine LT1/L83/L86
Suggested for normally aspirated engine applications with stock cubic inch, or larger cubic inch applications desiring a non-aggressive idle.
I'm not really sure of DOD compatible valve springs. That was one of the reasons I went with a DOD delete cam. Many vendors talk bad about the other guy's DOD compatible cam, and theirs works. IMO, all DOD compatible cams are suspect...
Old 11-29-2018, 09:23 PM   #38
oldman
Cam Specs: 223/227, .635"/.635", 116 LSA
TSP SV cam, or stage 0, it does retain a cam phaser for more "stock like" performance, VVT limited to 20 degrees. IMO I don't like the phaser, but it does offer better drivability.
https://www.texas-speed.com/p-5418-t...-camshaft.aspx
Old 11-29-2018, 09:35 PM   #39
biker2k
biker2k's Avatar
TSP SV cam, or stage 0, it does retain a cam phaser for more "stock like" performance, VVT limited to 20 degrees. IMO I don't like the phaser, but it does off better drivability.
that looks interesting
Old 11-30-2018, 07:22 AM   #40
Zboy136
Drives: Red Hot 17 1LE
I just had a texas speed stage 2 cam installed. For the most part it drives pretty close to stock, however there is some slight cam surge at the very low rpm's. That is to be expected unless you go with a cam so small its not really worth it.
Zboy136 is offline   Reply With Quote
Old 11-30-2018, 09:31 AM   #41
oldman
I think because Texas Speed designs their cam with phaser of 20 to 22 degrees, there is more "stock like" performance...
Old 11-30-2018, 10:53 AM   #42
6spdhyperblue
Drives: 2SS 1LE
And to clarify that’s a idle at 650rpm
