Old 09-26-2018, 02:10 PM   #29
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
Originally Posted by Chris V View Post
Are you guys pulling that DS aux radiator on an Air-to-air/centrifugal setup, or with the Maggie too?
Does the Maggie have an Air/Water coolant reservoir? The Whipple may be the heaviest with the metal lid, AWIC, leaving the aux radiator, and almost 3 gallons of coolant for the AWIC system with the bumper mounted tank.
My Whipple 1LE is heavy, but I haven't weighed it with the blower. It was 3,663 stock - so heavier than Laynlo's car, but it's a SS 1LE so the eLSD, wheels, brakes, etc all add up.
Only gets removed if running prochargers race intercooler I believe. I think the tuning is routed different and slightly larger and therefore that radiator gets in the way. Haven’t noticed any change in cooling, etc.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 09-26-2018, 03:24 PM   #30
RDBURNR
Drives: 2016 Camarro 2SS
The kit comes with an offset mounting bracket, probably a good idea to maintain all the cooling capability.
RDBURNR is offline   Reply With Quote
Old 09-26-2018, 03:41 PM   #31
Eyefixstuff
Mine did not. It came with a removal kit for it. Also this is the race IC, not stage 2.
Old 09-26-2018, 04:09 PM   #32
RDBURNR
Oh, that is the thickest and largest IC, my bad.
Old 09-26-2018, 04:09 PM   #33
oldman
Drives: SS 6 speed of course
for my street driven application, I felt that it would be a good idea to get as much cool air to the intake filter IMO of course. Plus if I up boost I have to put a second BOV in the hardpipe in the same area. Because my state II had the normal BOV and the race one is an expensive welding needed ad-on. I've already upgraded the head unit to a D1X, tempted on the race intercooler very tempted.
It would be my opinion that any road race / auto X setup have a forged engine and better cooling (oil cooler, side and center radiator) vs stock SS setup. I don't intend to do either.
Old 09-26-2018, 10:33 PM   #34
laynlo15
Drives: 2022 Lt1 A10
Mine is an A8.
Old 09-27-2018, 11:21 AM   #35
oldman
the Prochargher D1x, with oil, with the complete mounting system and all pulleys on the mount = 32 lbs. I'd estimate the crank pulley, three long bolts and spacers, intercooler stage 2, air filer, and two pipes / hoses BOV to be 35 lbs, - the stock intake, all the shrouds, 15 lbs = 53 Lbs, lets call it +60 lbs in total just for error sake.
Old 09-30-2018, 06:52 PM   #36
NinoSS
Drives: 2SS/RS CGM LS3
Here is what really matters, straight off the trailer with 60 lbs added to the front I ran 10.91@129.88 on 6.5 lbs of boost on Magnusons handheld SCT tuner. I think that's pretty stout and ran a best of 10.82@129 that same day on 93 octane pump gas with stock transmission and stock motor and then put the street tires on when I got home and got 25 mpg going to work on Monday. Many things have changed since then but weight is not always a detriment to performance
It seems the consensus is about 60lbs for both centri and PD... Thank you all for playing...
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 09-30-2018, 09:14 PM   #37
laynlo15
Yep, I'd say your right.
Old 10-03-2018, 10:46 AM   #38
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Speaking of weight.. the front clip is light till you put the Bezels back in, the fog lights, grills and plastic part w foam to cover the cross member.. should make an alternative. maybe carbon mesh support lol
Old 10-03-2018, 07:27 PM   #39
NinoSS
There was someone on Camaro5 that made and sold a bunch of tubular front bumper supports that shaved a few pounds off the front. I will see if I can find the thread.
Old 12-12-2018, 12:46 AM   #40
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
I gained 70lbs, TOTAL:
I went from 3800(3/4tank, large custom dual subwoofer box, amp, and “emergency kit(read 5.56&#128521.
To 3870lbs after Magnuson, LT headers, Cat delete, BUT, adding a 2.5 gal Meth tank.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 12-12-2018, 06:40 PM   #41
D K
Drives: C5
I'm curious about this also.
From all the research I have done, it seems the Procharger kit is about the lightest.
When you add in the 2 heat exchangers, water pump and the water itself, along with a much heavier blower unit, the PD kits are quite heavy.
I'm eventually gonna go with a simple air to air setup because I plan on tracking the car and no way the air to water setup can keep up.
Way too much heat soak.
D K is offline   Reply With Quote
Old 12-12-2018, 08:59 PM   #42
NinoSS
This seems consistent with what was stated earlier. Without the meth tank you would be about 10-20 lighter...
