Old 08-08-2018, 07:48 AM   #29
Gabhart
Gabhart's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Congratulations! Great car you will love.
Glad to hear so many good experiences purchasing from Becky. When I asked her for help she couldn't do anything for me. I found it odd but didn't question it.
I went with the GM splash guards, changed out the sticky and non-rain friendly tires to Michelin PS4S' and will be getting PPF on the front, hood and rockers. These cars take a beating on the rockers in front of the rear tires with the stock Goodyears. At a minimum get that area protected ASAP. The small area GM added protection to is simply not big enough.
Gabhart is offline   Reply With Quote
Old 08-08-2018, 08:07 AM   #30
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
Originally Posted by carguy55 View Post
Yes to the deluxe rock guards even with ppf.
Have the alignment checked. Check the lug nuts, should be torqued to 140 ft-lb.
Have fun!
Do I need the front and rear deluxe guards? Or will just fronts be sufficient
artey34 is offline   Reply With Quote
Old 08-08-2018, 08:15 AM   #31
Alex74
Alex74's Avatar
Drives: 2018 NFG SS 1LE
I put on both front and rear ZL1 deluxe rock guards - partly as the Goodyears flick up every loose stone or bit of debris from the road surface, and secondly as I like the aesthetic balance of having front and rears.
If you are thinking of switching to the LED side markers, you might want to do those first then install the rock guards - saves a bit of future faffing...
Alex74 is offline   Reply With Quote
Old 08-08-2018, 12:49 PM   #32
artey34
artey34's Avatar
Ok front and rear deluxe ordered! I will for sure install both those and side markers at the same time
