Old 05-02-2018, 02:01 PM   #29
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by JaxChris View Post
It proves that the catch can is not needed on the GM Gen V. Your runners won't be any cleaner than that after 100k unless you vent to atmosphere.
While a catch can may not be required it does catch oil that makes it's way back into the intake manifold and heads. I don't know about you, but the only thing I want in my combustion Chambers is air, fuel, and spark.
Old 05-02-2018, 02:08 PM   #30
Gunmetalmissle
Drives: 16 ngm ss
Originally Posted by GuywithL86 View Post
guy is providing me with more info, confirmed he used 0w-20
So basically what we have here is the worst possible conditions for carbon buildup.
-Long intervals between oil changes (9-12k)
-No catch can
-over 100k miles
-0w-20 oil, aka super thin, which undoubtedly allows more oil into the intake since there are numerous records of the truck motors burning it through the intake via AFM
extreme carbon buildup theory circulating all GM DI v8 forums = pretty much busted (we'll of course need more high mileage examples to make it 100%)
Thank you 00pooterSS of performancetrucks
I agree it is worse case other than the fact that he used full synthetic dexos approved oil.
Gunmetalmissle is offline   Reply With Quote
Old 05-02-2018, 02:09 PM   #31
6spdhyperblue
Drives: 2SS 1LE
Right? You can lead a horse to water...
That’s a different story tho. Not diluting the intake charge is a legitiment reason to run one. Especially if you’re tuned. That’s when I’ll buy one.
Old 05-02-2018, 02:32 PM   #32
KingLT1
KingLT1's Avatar
That is precisely why I bought one.
Old 05-02-2018, 02:58 PM   #33
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
All great stuff in here. I actually like this thread better than most I've read in the past month. Learning stuff!
Old 05-02-2018, 03:28 PM   #34
Spartan268
Spartan268's Avatar
Drives: HB 2SS
-No catch can
-over 100k miles
I'm so glad for this. Hopefully we can see some high mileage camaros soon. Gives a lot more peace of mind considering the coking and A8 is the two things that makes me iffy on keeping this vehicle long term.
I'm not running one so even better. But careful what you say. I'm surprised a certain vendor hasn't chimed in yet
Spartan268 is offline   Reply With Quote
Old 05-02-2018, 06:20 PM   #35
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
So if the SAE paper cites that they found that the significant portion of carbon buildup on the valves and intake came from the exhaust gas, then I wonder what eliminating the EGR effect in the cam timing will do over the long run.
Since you can tune out the EGR over retard at light loads, this maybe will eliminate a lot of that?
cmitchell17 is offline   Reply With Quote
Old 05-03-2018, 05:52 AM   #36
JFM-jr
JFM-jr's Avatar
Everytime I dump oil out of my catch can I will remind myself to read this thread again.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 05-03-2018, 07:41 AM   #37
parbreak
Drives: 2017 50th Camaro SS
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 05-04-2018, 10:39 AM   #38
GuywithL86
Drives: Black
to remind you how much of a waste of time it is?
GuywithL86 is offline   Reply With Quote
Old 05-08-2018, 04:58 PM   #39
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
Looks like a BMW or VW after 12K miles
S2K+1LE is offline   Reply With Quote
Old 05-08-2018, 05:17 PM   #40
Mavericka70
Drives: '17 1ss m6
14k on my lt1, had it apart for a cam swap. 5k between oil changes, 5w30, no mods until now.
Mavericka70 is offline   Reply With Quote
Old 05-09-2018, 12:08 PM   #41
GuywithL86
Drives: Black
looks pretty much identical to the one with 117k, interesting
Old 05-09-2018, 12:22 PM   #42
Gunmetalmissle
Drives: 16 ngm ss
Synthetic oil?
