Old 04-19-2018, 07:38 AM   #29
Nrfd79
Drives: 2018 ZL1 1LE
Originally Posted by mdbennes View Post
That's a dream cave...BADASS!!
Thanks Its hard to go in the house.. Lol
Nrfd79 is offline   Reply With Quote
Old 04-19-2018, 12:08 PM   #30
Navigator
Navigator's Avatar
Drives: 2020 Camaro 2SS
https://www.garageflooringinc.com/ti...l-tiles.html#!
This is what I've been looking at and great deal on the tiles...I think for a 20x20 size floor its about $252 for the tiles.
I like the price, but I'm guessing you need a pretty level floor without any cracks or ridges for that to work unless those are real flexible tiles that can go over some minor humps and uneven spots.
Navigator is offline   Reply With Quote
Old 04-19-2018, 01:17 PM   #31
detltu
detltu's Avatar
Drives: 1992 Z28 1LE; 2015 Zl1
Buying a new house with a 30x80 garage/shop. Can't wait to start turning it into the Camaro Cave. Still probably a month or two from moving in so loving the ideas here. I've been planning for a while and have a pretty good idea of what I want to do. Always love to see new ideas though.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x
1991 Camaro Z28-
1991 Camaro Z28 1LE-
1992 Camaro Z28 1LE- 25th anniversary
2015 Camaro ZL1
detltu is offline   Reply With Quote
Old 04-19-2018, 06:46 PM   #32
Lerch98
Lerch98's Avatar
Drives: 2017 2SS black on black on black.
Snow Bound Camaro
Garage Queen still waiting for spring
Lerch98 is offline   Reply With Quote
Old 04-19-2018, 08:30 PM   #33
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
The typical epoxy floor kits you get at the big box store won't hold up over time to acids, petroleum products, or high heat, like a hard run motorcycle tire. My neighbor came pulling into his garage after a hard run on his motorcycle and pealed up a strip of the cheap stuff around his back tire.
To do it right, I use two versions of the PPG Aquapon two part epoxy. Clean, sand and acid etch the floor to get all of the contaminates off, then rinse thoroughly and let dry. The cleaner, the better. Your base coat should be with the water based Aquapon (?). The top coat should be with the solvent based Aquapon (35). These two products are compatible with each other. The water based Aquapon will flow into the micro-pores of the concrete and reduce/eliminate bubbling. The top coat, solvent based, epoxy is impervious to almost anything. Follow all directions, vent well, and use a respirator. This stuff is used to coat pipes that are immersed in sea water and will handle solvents and battery acid.
My house garage floor is going on 20+ years and still sealed. It does have some stains in it, but the integrity is still good after all of this time.
Here's my new toy shop with the Aquapon treatment. I love my central heating and air system!
Atomic Ed is offline   Reply With Quote
Old 04-19-2018, 09:18 PM   #34
Ryanbabz71
Ryanbabz71's Avatar
Ryan B.
Ryan
Old 04-20-2018, 01:15 AM   #35
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Originally Posted by Atomic Ed View Post
I love that loft! I am thinking about doing similar to my deep part of the garage. Probably not a necessity right now since I have only 2 cars in a 4 car space, but maybe someday.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 04-20-2018, 08:54 AM   #36
BMP-1LE
BMP-1LE's Avatar
Drives: 2017 1SS 1LE
My Garage Progress
Pic Heavy but here is my Garage
The pile the previous owners left of "stuff they thought I could use" lol
Hauled away with a few swipes on the ole smartphone
Blank Slate
Boxed out the AC lines
Cabinets and Paint Completed
Cabinets are NewAge Pro 18 G
Merica -
My detailing quick grab wall
Once the SS arrived went from one overhead to a full locker of supplies
BMP-1LE is offline   Reply With Quote
Old 04-20-2018, 09:21 AM   #37
mdbennes
mdbennes's Avatar
Drives: '18 Silver SS 1LE
Blank Slate
Merica -
Great pics....I'm doing the same thing, getting gladiator cabinets and slowly doing the same thing. I have a 3 car garage, and looking to wall off the single car portion to make my wood shop. That way the two car side is just for the 1LE and my girl's new Nissan Rogue.
Retired Air Force (2014)
2018 Silver SS 1LE
Past Rides
2000 Corvette FRC
2000 Corvette Coupe
2002 Corvette ZO6
2005 Corvette Coupe
2016 Corvette Stingray
mdbennes is offline   Reply With Quote
Old 04-20-2018, 09:49 AM   #38
Interceptor9c1
Drives: 2016 Camaro SS
Just started to to-do my 2.5 car garage. Also double car port in front of it
Interceptor9c1 is offline   Reply With Quote
Old 04-20-2018, 09:50 AM   #39
Atomic Ed
Thanks! It added 300 sq. ft. of storage. Still not enough storage with the S.O.s' stuff!
Work bench going in the middle under the loft. Welding bench, welder, chop saw, drill press to the left; and refrigerator, coffee stand, loading bench to the right. 60 gal air compressor in its own shed outside to keep the noise down. Probably a Max Jack lift next to the stairs.
6" of insulation in the walls and 24" in the ceiling. The central heat/air rarely kicks on.
This summer I'll also be adding a 20' X 32' lean-to on to the shop for a place to park my truck and...more storage for the little lady.
I'm retiring at the end of the year and this is going to be my hangout.
Old 04-20-2018, 03:57 PM   #40
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by Navigator View Post
I have an old concrete garage floor that is stained and not looking too good. Any ideas for inexpensive and easy-to-install flooring options to make it look nicer?
If least cost is your priority, then pick out a cheap sheet vinyl flooring from the local home store. I did a parquet style sheet vinyl floor in the garage of my last house and it looked great... well under $1/sf for the material. You can do a 20x30 garage for under $500, including $50 to rent the truck to take it home.
https://www.homedepot.com/b/Flooring...l/N-5yc1vZar9y
Old 04-20-2018, 04:23 PM   #41
Navigator
Navigator's Avatar
That's a good idea.... How did it hold up over time? Did you just use some type of concrete or construction adhesive to hold it in place? Was traction an issue?
Old 04-20-2018, 05:43 PM   #42
Gunkk
Gunkk's Avatar
Lasted me 12 years just fine until I sold the house. Traction was fine, but obv not as good as concrete when wet. VERY easy to keep clean.
The key is if you have a standard 2 car garage, the vinyl probably won’t span the entire floor in one piece. So glue the seam well and locate it in the center, etc. so the tires won’t contact the seam. Or just lay a piece of threshold on the seam later if it starts to curl after 5 or so years. Use a piece of threshold for the front lip and any other doors. The standard vinyl floor glue they offer works fine. I used 10 gallons of glue for a 20’ x ~30’ garage. Get the 1/4” square tooth trowel.
When you first lay it down it will bubble no matter how well you roll it out. You can pin prick it or just let it settle on its own in about a day.
