Old 06-12-2020, 11:58 AM   #29
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by 2K16SummitSS View Post
I used blue last time (it was what I had on-hand). I will use red this time. I'm also going to look at my stake job when I take the wheels back off. May need to stake them better this time. Only things I can think of to change.
How did you stake them? I don't believe there is a hole in the axle for a stake to go through...
Old 06-12-2020, 01:23 PM   #30
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
Shop manual calls for a hammer and suitable punch to stake the outer collar of the nut into the slots after torquing.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 06-12-2020, 03:58 PM   #31
2SS Capt
2SS Capt's Avatar
Ah, ok...
Old 08-12-2020, 01:07 PM   #32
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
Any chance you could post the entire section of the shop manual for this job? Just want to make sure I don't miss a step. Can the new nut be torqued with the rear suspension unloaded, or does it need to be loaded? I wouldn't have known to peen the outer nut flange over without this info. Thanks in advance.
DFW_Muscle is offline   Reply With Quote
Old 08-13-2020, 03:02 PM   #33
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
199 ftlbs lol! I suppose 200 is just too damn much!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 08-13-2020, 03:13 PM   #34
2K16SummitSS
I uploaded the entire manual to Dropbox. It's a chonker of a PDF at 236MB.
Start at page 4632, and let me know if there is any trouble with the link.
https://www.dropbox.com/s/3dblnnpnhp...anual.pdf?dl=0
Edit: I would download the file and navigate with Adobe Acrobat, Reader or equivalent. It is broken up into sections that are much easier to see and get through with a decent PDF app.
Old 08-13-2020, 05:12 PM   #35
DFW_Muscle
Awesome reference material; thank you VERY much for doing this!
Old 08-13-2020, 05:20 PM   #36
OVRKLL
Thank you 2016!
Old 08-17-2020, 08:26 AM   #37
2K16SummitSS
No problem
Old 09-01-2020, 12:06 AM   #38
3.8TransAM
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula
Just found this, plan on ordering a 21, but a lot of still applies! Thanks!
3.8TransAM is offline   Reply With Quote
Old 09-01-2020, 08:11 AM   #39
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Mine were staked and loosening up to the stake mark. I just hit mine with the electric impact and they tightened quite a bit, i will continue to do this every so often. A lot of ugga uggas is just fine torque for me on a 36mm nut.
Old 09-06-2020, 06:24 PM   #40
hep4186
Drives: 2017 Camaro 2SS
Picture of the axle nuts?
Can someone post a picture of these axle nuts? I bought a 2017 2SS convertible a few months ago. Just turned 19K miles. Want to heck them on my car. Is it obvious once you take the wheel off?
hep4186 is offline   Reply With Quote
Old 09-07-2020, 01:27 PM   #41
2SS Capt
2SS Capt's Avatar
Once you take the wheel off it is the big 36mm nut in the center of the hub... Looks like a crown, can't miss it...
Old 11-03-2020, 09:49 PM   #42
MackSteelPrivateEye
Is there a TSB?
