Old 01-03-2018, 03:54 PM   #29
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I'm going the route of buying used SS wheels and likely getting the new General G-MAX AS-05 tires in 255/35 and 275/35 sizes. Hopefully by the end of this month. Seems to make the most sense to me instead without having to compromise on Summer Performance. I'll keep the OEM Supercar 3's for track and autox use. Daily commute on the All Seasons.
Old 01-03-2018, 04:55 PM   #30
shawndean22
Drives: 2017 Camaro 1LE
Originally Posted by Eldi Z View Post
And you manage to drive just fine daily during these extremely cold days? Wow. This is impressive indeed!
How does the engine crank up in the mornings?
Can you share? I am terrified by the thought.
Maybe you can calm those who are worried about driving the car under 20-30s and the tires cracking issue?
Engine cranks slowly in the morning. I had a 350z and Mustang before this so i am used to RWD in the snow. Pretty easy and carefully actually.
Cold days and dry is fine once tires are somewhat warm, no slippage at all. Obviously i am not driving full throttle, driving around 2-3k and occasionally go to 4-5k on the highway.
I am not worried about cracking tires as i drive the car everyday. Now if it were sub zero temps might be a different story. But 20s so far so good.
I also got caught in that snow dusting few weeks back in December. Took about 1.5h to drive 40 miles but made it home fine. Would fishtail at every stop light and every shift. Once i got to the highway it was fine as it had no snow cover.
I wouldn't recommend driving 1-2 inches or more as you may/probably get stuck.
Where i live the roads are clear the next day or two, so i do not have to worry about driving with accumulation on the road.
shawndean22 is offline   Reply With Quote
Old 01-03-2018, 05:41 PM   #31
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Sir, I salute you for managing to drive our car like this and on the stock tires!
My other location (where my car is right now, but I am not...) is Englishtown and the car is not driving for the past 2 weeks or so.
I have a friend take care of it while I am away. I told him not to drive during the next 5-7 days or so, until it warms up a bit.
It is also encouraging to know from your first-hand experience these days, that the tires can take these Temps when driving carefully.
Old 01-03-2018, 05:53 PM   #32
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
This is the most economical and practical solution as of now.
You can get a set of used rims and stock SS size all season tires for what a set of 285-305/30R20 rubber costs. They will fit and function like factory, and tires are a little over half the cost of 1LE rubber.
Old 01-03-2018, 06:04 PM   #33
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I suppose you could go 1 step further with V6 wheels and 255/35's on all 4 corners so you can rotate.
Old 01-03-2018, 07:37 PM   #34
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
You are going to rear end somebody in a panic stop.. G3's do not grip below 40. Stomp on the gas and see what happens at 35 degrees..
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 01-03-2018, 07:49 PM   #35
Dale Dirtheart
Drives: 2018 2SS 1LE
I've been driving in the 20's all week. Car is stored outdoors and its been almost single digits. Tires have not cracked and drives just fine.
Dale Dirtheart is offline   Reply With Quote
Old 01-03-2018, 08:03 PM   #36
pbsinternet1le
Run it up to 70 and panic stop.. not sure what yall are thinking.. it's way dangerous...why would you risk hurting your car, yourself, or someone else over a set of tires...? Makes no sense to me..i could drive 100mph in the rain but I choose not too...
2017 1LE Hyper Blue
Old 01-03-2018, 08:12 PM   #37
Dale Dirtheart
I have one car and there is no other option.
Old 01-03-2018, 08:20 PM   #38
pbsinternet1le
You really should consider a winter set.. you may end up with no car... $800 set of rubber could save your life. G3s are in no way safe below 40 degrees.. don't kid yourself. Can you drive it ? Probably.. should you drive it? Definitely not...they do not grip.. be safe! I see you have an 18... nice ride!
2017 1LE Hyper Blue
Old 01-03-2018, 08:47 PM   #39
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I've been driving with BFG Comp2 A/S.
No issues as long as you drive properly.
Hopefully everyone else on the road can.....
Old 01-03-2018, 09:02 PM   #40
pbsinternet1le
👍Good Choice! I've had a set and i thought they were great for daily on a gen 5..Although not available in 30 series. I put mine up for winter this year. I would consider the continentals for gen 6 on stock sizes available....
2017 1LE Hyper Blue
Old 01-04-2018, 10:08 AM   #41
shawndean22
Yes, we know the limitation of stock tires when it is cold/snow/wet. We are not going to be driving 70 mph or stomping it in the cold. I give plenty of room for braking as i know what would happen, and let people pass me if im driving too slow. It is not ideal, but can be done very carefully. Not buying a winter set of wheel, for when it maybe snows twice a year and in the 20s for maybe 2 weeks. When is just cold and dry it is fine to drive at those speeds... been doing it past few years.
Old 01-04-2018, 08:10 PM   #42
pbsinternet1le
G3s have not been out for"several years" so that is not possible. Why would you risk wrecking a 45k car over a safer set of tires? I don't get it..plus if they do crack you're buying a new set anyway.. keep in mind they may not crack right away. Cracks may show up later..
If you have to leave extra room cause you "know what would happen" you already know you shouldn't be driving these tires in the cold.
2017 1LE Hyper Blue
