Old 08-27-2017, 08:09 AM   #29
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Nice!
How did you access to the center pylon in the inside of the trunk to switch wing?
Easy for the left and right,
But for the other one?
Did you have to remove all the protection, the third brake light?
Any picture?
Thanks
Biscuit.fr is offline   Reply With Quote
Old 08-27-2017, 10:52 AM   #30
ZL1-14
Drives: 2018 ZL1 Conv. A10
Originally Posted by Biscuit.fr View Post
Nice!
Any picture?
Thanks
Yeah have to remove inside trunk cover. Also the truck latch come off with 2 torx 30 bolts. Still a little challenging but not to bad.
Bigger pain on convertible was jamming and protecting the antenna. Took about 4 hrs, that was with also making a reinforcement plate to help spread the down force load.
ZL1-14 is offline   Reply With Quote
Old 08-27-2017, 11:20 AM   #31
vy427
Drives: '21 ZL1 A10 Convertible
It's too large a wing for my taste, but I gotta say, it looks better on the convertible than I thought it would.
vy427 is offline   Reply With Quote
Old 08-27-2017, 12:53 PM   #32
psalmon123
Drives: 2015 Z07 2017 ZL1
What did you do with the antenna? I'm installing mine next week.
psalmon123 is offline   Reply With Quote
Old 08-27-2017, 01:02 PM   #33
Biscuit.fr
Thank you
Old 08-27-2017, 03:07 PM   #34
ZL1-14
There are 2 antennas about 18-24" in spoiler. When you remove access panels to spoiler bolts you will see two signal boosters that the antennas are connected to. Once I unhooked and removed antennas. I slid one from each side and crossed in middle behind trunk latch. I warped both end in 1/4" foam in access panel area and zip tied, then where they crossed in middle did same thing. Made sure would not rattle and were not touching any metal.
Bigger issue is the forth hole. Gonna get quote from body shop to fill and respray, but most likely will make a cover out of carbon fiber.
Talked with That Gm Guy and he said he was unaware of the issue and would add a note to website. (still not sure if this is just on 18' convertible model year or not)
Old 08-27-2017, 05:01 PM   #35
psalmon123
Thanks for the info. Mine is a 17' and there is no additional holes, just the stanchions that bolt to the trunk lid. The footprint on the 1LE wing looks identical to the stock ZL1.
Old 08-27-2017, 08:24 PM   #36
Mpsmith1
Mpsmith1's Avatar
Drives: '19 ZL1 1LE
Wing is $2800.00 here: https://www.thatgmpartsguy.com/zl1-1le-edition/
I received mine and it is beautiful.
But OP has a 5th, so that one won't work. Right?
Sent from my iPad using Tapatalk
Mpsmith1 is offline   Reply With Quote
Old 08-27-2017, 08:38 PM   #37
psalmon123
I do not believe it will.
Old 12-04-2017, 08:17 PM   #38
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Originally Posted by Infern0 View Post
Why is it over $4K on their site?
So I guess they raised the price on this as well now?
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 06-15-2018, 10:56 AM   #39
Ttiscio
Drives: 2017 ZL1 Convertible
Update
So since its been a while, has anyone come up with a solution to this without body work to the deck lid? I would also like to add the wing to my 17 convertible, but I have the antenna holes on both sides and am concerned about them not being covered!
Ttiscio is offline   Reply With Quote
Old 06-15-2018, 06:26 PM   #40
psalmon123
Just finished mine. There was a small portion of one hole that showed when mounted. Welded up the hole, painted the trunk lid and bolted her up. Came out absolutely beautiful. Everything else including the top works great. All the other stuff is a bunch of wives' tales. Well worth the time and investment.
Old 06-10-2019, 01:33 PM   #41
BrotherxSpartan
Drives: 2017 Camaro SS
I don't know if any less invasive solutions (like wider stanchions) have come into being since this thread was created.
But seeing none via Google search, I am going to have a body shop fill and paint the holes.
BrotherxSpartan is offline   Reply With Quote
Old 06-10-2019, 01:57 PM   #42
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Definitely looks different ZL1-14 and not in a bad way I must say! Not a fan though but if you like it then that’s what matters! I don’t think Chevy will ever build a ZL1 1LE vert because of the coupe being a specific track car. Someone probably would get killed in one if it had an accident on the track(no hardtop) and Chevy would be in a lawsuit!
LT4Greg is online now   Reply With Quote
