#29 |
![]() Drives: 2016 Camaro 2SS Join Date: Aug 2018
Can anyone confirm if there are any issues with VVT2 and stock torque converter? My shop said going to a VVT3/4 would require a different torque converter, but a VVT2 should be fine, but now I'm nervous heading into install!
#30 | |
Instagram: @SSAVAGEVERT
Drives: 2016 SS M6 Vert Join Date: Jan 2016
That is correct. VVT-2 still gives you a stock ride when stopping. VVT-3/4 would require a stall change.
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build |
#31 |
#32 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Since you are looking at this for a Z, why not just contact Jannetty (forum vendor) and get a package for everything you need? I just installed his rough idle cam and love it. He also has a smooth idle cam...
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#33 |
![]() Drives: 2ss Join Date: Jan 2018
#34 | |
Chain can com off gear so you don’t have to remove pan don’t pin the tensioner, as there is more slack not pinned for removal I took out my condenser but for 2017 up the r1234yf freon will tear you anew hole,radiator was a pain get the tool to remove the gum spring clamps There are guys that just drop the condenser OP wanted cam sounds there are big compcam vvt compatible cams, yes they are down hp, but should be gentle on valve train I have m6 so don’t know how big you can go with stock verter. OP, I’d go comp cam vvt mild springs go with a mid duration grind and tune,no need to pull head
