#29 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Some of our joints are shperical ball rose joints. They are not affected by static ride height changes. Bind free precision movment. Perfect joints. This bind effectively changes the OE calculated wheel rate for which the struts and shocks are tuned for. This is the rate or "stiffness" of all the suspension components that the wheel or more correctly what the tire is seeing, not just the springs and bars. Joints are part of the wheel rate. This bind is uncontrolled, undampened.
"KEEP THE FAITH"-Fbodfather |
#30 |
![]() Drives: LT1 Join Date: Apr 2024
I overlooked the sway bar mounts when my suspension bushings were timed during my coilover install. To time the rear sway bar mount bushings at static ride height, do you think I'd be able to get away with loosening the bolts to the rear sway bar mounts, jouncing the car (stand in trunk and jump up-and-down), then retighten the rear sway bar mounts?
#31 | |
You can remove the bar and then remove the brackets, bushings/resinstall and resest to your ride height or do it all with the bar on the car. Removing the bar sucks unless you do it on a lift. -Mark the bushings with paint stick or something to make a reference of the OE position. -Make marks for lateral and radial positions. -Remove the metal brackets. They are gonna be tough to free from the rubber bushings. swing them side to side while pulling on them. Sometimes it helps to use a flat screwdriver tip or a short pry bar in the bracket holes to kinda pry them side to side. They'll start working off. You don't have much room. But if I recall correctly you can atleast get at the bottom holes. -The rubber bushings will have a split on their flat area. Spread them here, don't spread more than you have to. They are rubber but have either a metal or plastic core. -Reinstall at your new ride height. Note that the OE bar has a preload, even at OE ride height. I don't recall which way the bar is preloaded, up or down. It's possible that OE preload may make the bar neutral at your new ride height! You can choose to duplicate this OE preload at your new ride height, but you can only observe the OE amount with an unmodified ride height, obviously. I believe GM adds some preload to add responsivness to the bar. -When I repositioned the OE mounts on my Gen 5 SS 1LE (same style), I used some hand soap as a lubricant on the bushing to bar surface. This allowed me to easily position the bushing and adjust if nessecary. The Devil's Lube (spit) can also work. Both will eventually dry and allow the bushing to grip as intended. Let both dry before driving. -Reinstall the bracket. The fasteners are 43 lbs/ft. There's alot going on with the OE rear bar. Not only do they have an overall preload but a slight twist too, which then adds more (or less depending on perspective). The super grippy mounts add a slight amount of overall rate. The front bar just has a little preload, a slight twist in the bar. But the front bushing is actually glued to the bar! I half-heartedly attempted to remove the bushings from my front bar once but felt it wasn't worth the squeeze just to understand it further. When we install aftermarket bars with their lubed poly bushings, there is no grip on the bar. EDIT: I see your sig says LT1. My observations have been with the SS 1LE, ZL1, ZLE. I believe your LT1 does have the grippy mounts but the OE preloads, if any, may be different.
"KEEP THE FAITH"-Fbodfather Last edited by cdb95z28; 08-09-2025 at 06:31 PM. |
#32 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
The obvious-but-costlier solution to the sway bar bushing dilemma is to install aftermarket bars with urethane frame-mount bushings. The Whiteline rear bar is the same diameter as stock and about the same rate as stock in its middle setting. The BMR front bar is close to stock rates in its softest setting. The bushings that come with the BMR bar are junk, though, so you need to buy a substitute, such as the ones that came on the Hotchkis bars.
Matt Miller
2020 SS 1LE |
#33 |
Gents, thx for chiming in!
It's an LTI, so same suspension as an SS. (But, I've got KW coilovers, spl rear toe links, and BMR rear subframe lockout.) Car is roughly 1.5-2" lower than stock. All bushings (aside from sway bar mounts) were retimed at new ride height. The performance on twisty roads is great; sharp turn in, takes a set, etc. It's the most compliant set of coilovers (or aftermarket spings/shocks) I've had on a car, very refined. That said, I'm a suspension nerd, and it bothers me that there's a potential compromise in the setup that could have been avoided. Generally speaking, my preference is not having sway bar preload, but it's a subjective thing. I also tend to prefer the feel of stock sway bars over aftermarket. All considered, I'll likely leave it (KISS approach, no can-of-worms) or possibly swap in aftermarket bars. |
#34 | |
![]() Drives: 2017 Summit White V6 1LE Join Date: May 2018
#35 |
Sorry, I'm not well informed on the V6 1LE package.
#36 |
#37 |
![]() Drives: 2023 2SS 1LE Join Date: Dec 2022
Sounds like an install issue or wrong part number, lol. The 1LE Eibach Springs, although progressive, have overall the same feel as OEM and almost identical max spring rates. They're very predictable.
#38 |
![]() Drives: 2022 1SS 1LE Camaro Join Date: Apr 2014
Mix some key lock graphite in the silicon grease. Stops squeakies.
