Old 06-12-2017, 10:32 AM   #29
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
Originally Posted by Dysan911 View Post
Thanks. Contacted Procharger this morning and all signs point to a bad Maf Extension cable. Getting a replacement sent out to me. Hope that clears it up.
Outstanding hope you get it fixed asap..
Perdieu is offline   Reply With Quote
Old 06-12-2017, 04:04 PM   #30
lcarney1977
Drives: 2016 CAMARO SS
how much did you pay for that procharger intake manifold and where you get it thx..
lcarney1977 is offline   Reply With Quote
Old 06-12-2017, 04:39 PM   #31
Perdieu
Perdieu's Avatar
It was part of my deal for testing out the Air to Water set up..
Any ProCharger dealer can get you prices on it.
Old 06-12-2017, 05:01 PM   #32
jwdominick
Drives: 2017 50th 2SS
"system to rich" "air flow volume"
Check your MAF plug and make sure its plugged in and not messed up.
exactly what I was thinking too
jwdominick is offline   Reply With Quote
Old 06-13-2017, 02:46 PM   #33
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
New maf extension cable didn't resolve the problem. Last time the car ran fine was before pulling the PCM to send back for final tweaks.
I've checked that maf cable / Maf plug a dozen times and see nothing wrong with it.
Dysan911 is offline   Reply With Quote
Old 06-13-2017, 03:55 PM   #34
Perdieu
Perdieu's Avatar
CRAP..
Old 06-13-2017, 04:04 PM   #35
jwdominick
all this dinking around sucks for you I am sure. I am glad they are continuing to help you though
Old 06-13-2017, 04:36 PM   #36
ProCharger
Drives: Many C7's
The first time that the code for the baro got missed was 110% my fault. :(
The "codes" section of the ECU is in a totally different place, and after I got done with all the normal code changes... I just spaced on shutting the baro code off.
This new issue, however, must be some sort of tune file corruption.
Since the data that runs the car hasn't changed from the previous file.
(well at least on my end)
I have emailed Brian a call tag to get his ECU overnighted back to us.
I will fix whatever bug is going on with it, and get it back to him overnight.
My public apologies to Brian, since this isn't normal, and the only 2017 I have had this issue with. I am sure it will be resolved, and apologize for the inconvenience.
Erik
ProCharger is offline   Reply With Quote
Old 06-13-2017, 04:52 PM   #37
jwdominick
Erik
Old 06-13-2017, 04:58 PM   #38
Perdieu
Perdieu's Avatar
Erik
Keep learning Grashopper.. you'll have a fun one to play with soon
Old 07-03-2018, 08:34 AM   #39
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Ahh ok will do!. THank you for letting me know.
The codes I keep getting are
p0121
p2227
p2229
So what was done to get rid of the P0121 code? I am getting this code with me Whipple.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 07-03-2018, 09:59 AM   #40
Dysan911
Dysan911's Avatar
Wow brings back memories. Seems so long ago. lol. The cause of those codes at that time was some misfires from a bad #7 plug, A bad MAF Extension harness and a baro code wasn't addressed via tuning when it was sent in to Procharger.
Old 07-03-2018, 12:47 PM   #41
ProCharger
Drives: Many C7's
Its in the tune. Not a big deal... just have it addressed and you'll be fine.
Old 07-03-2018, 01:14 PM   #42
Jhunsberger
Thank you for the reply, good to know!
