Old 05-21-2017, 09:05 PM   #29
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Great job, bet you will have it in the 10s with a little more time.
Sent from my SM-G955U using Tapatalk
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 05-21-2017, 09:36 PM   #30
big dave
Drives: 2017 ZL1
Originally Posted by Xlr8ion View Post
Now thats faster than a Zo6.Not sure your car is not modified?????
I'm really surprised it took this long to ask this question. There's no way to prove that my car is not modified other than my word...which means nothing to folks who don't know me. All I can say is I really didn't expect this car to be this fast. To be honest, I do question the mph because my speedo was showing 128 mph when I crossed the traps. I don't question the et though.
I've had the car for exactly 3 weeks. I've done my best to break it in properly and it looks like I may have done something right.
Just like my 5th gen, the only mods I would consider at this time would be a RotoFab intake. I no longer have a desire to modify cars.
Also, like my 5th gen, my goals are to get the quickest stock times possible before doing anything to the car.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 05-21-2017, 09:38 PM   #31
big dave
Drives: 2017 ZL1
Originally Posted by Artos View Post
Can you expound on this a bit more...was 1209rpms where you were from the stop & riding the brake in regard to slip??
The 1209 was a misprint, lol. I was actually trying to say 1200. I'll try to get the video posted at quickly as possible, I had 3 friends there all doing videos.
Old 05-21-2017, 09:48 PM   #32
762CAT
762CAT's Avatar
Drives: 2016 Challenger Hellcat
Ok I'm a bit bored with some time on my hands soooo….
This is a head scratcher for me. I've seen quite a few 17 ZL1 time slips now and they typically have a fairly high trap speed for their ET. Now drag racing 101 says the 60ft is key for ET and it's fairly obvious this cars 60ft issues are killing that aspect. On the other hand higher HP normally means higher trap speeds and some wheel spin can also increase trap speed. All that being said I still have a hard time figuring some things looking at the time slips and particularly this one.
I looked at a time slip I have where I ran a 10.74 and here are the numbers side by side.
660'.....1.749……1.616
330'…4.854………4.526 (.328 delta)
1/8……7.346……..6.928 (.418 delta)
Mph….97.74…….101.58 (3.84 mph delta)
1k........9.454……Track does not record
1/4....11.227 @130.42……..10.740@128.46 (.487 delta and 1.96 delta in mph for 5.8 mph gain)
From the 1/8 to the 1/4 the ZL1 makes up 6mph? Is there a strong tail wind? The HP numbers and the results of now many roll races seem to indicate the Hellcat pulls on the Zl1 at the top end. Here we see, despite the nearly half second difference in ET that seems to be refuted? It seems illogical and I'm just trying to figure it out. The difference in 60fts is there but not a 1/2 seconds worth in overall ET difference. Is there some other factor I'm not considering? The time slips are real so what accounts for this? Anybody have an idea?
Pure academic curiosity and late night boredom demand an answer.
Fly a 850whp HellCat Challenger
Drive a 19000 HP C130J
Reserved parking for ZL1 1LE….whoops filled the spot with a Charger Hellcat daily…….
762CAT is offline   Reply With Quote
Old 05-22-2017, 12:26 AM   #33
Zl1steve
Drives: Zl1
Awesome man. You ran 11.22 I ran 11.20. Your best was 130 mine 128.
Zl1steve is offline   Reply With Quote
Old 05-22-2017, 12:29 AM   #34
Zl1steve
Drives: Zl1
Dave mine was reading 128 also on speedo. But I ran 99 in the 1/8.
Old 05-22-2017, 12:36 AM   #35
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
First of all, great run bigdave!! Very good times! That 130.....holy $!#*!
762cat, you have a very good question. I thought.....well, you're definitely on a drag tire to get the cat to 60' that good and run the time you did, so maybe there's more rolling resistance versus the street tire on the Z. Maybe. Especially if you were running less air pressure than his 27 psi. The real head scratcher is, how do you gain 6 mph but still lose .07 seconds in the final 1/8 mile. It had me curious as well, but I think I can see the possibility. Whether it was rolling resistance, head wind, tail wind, better aero, or any combination of things that led to the higher gain in speed, the Z was stilling losing time as each car crosses the 1/8, evidenced by the higher trap speed by the cat. So the Z would've continued losing time until it matched the cats speed and then actually gained a little back once it started traveling faster, but simply lost too much time in the first part of the 1/8, to record a gain in ET. So it is possible, but the question now becomes, what led to the difference on the big end. Did you lose power for some reason? Did you have a head wind? Etc., etc.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 05-22-2017, 12:39 AM   #36
KenB925
Drives: Raptor
Perhaps it's the 10 speed keeping the engine in the sweet spot
KenB925 is offline   Reply With Quote
Old 05-22-2017, 05:10 AM   #37
big dave
Drives: 2017 ZL1
Like I said before, I do question the mph also. I think the mph should've been around 127 or 128. On my first pass, the car ran 11.46 @ 123. I thought the car should've picked up more mph after the 1/8th so I decided to change lanes. On that first pass, I got wheel spin and it felt like the computer shut everything down. The car never seemed to pull hard at all after that. I was actually shocked it ran that quick on that pass, it honestly felt like a 12 second pass.
On the second pass it was very clear to me, and everyone else who watched it, that it was a totally different car. I stuck the launch and the acceleration was fierce. I don't know exactly what they have programmed into this car, but I think that because I was able to find a way to launch in a manner that avoided torque management intervening, I had full power throughout the pass which netted this time. Like I said before, I think the mph is questionable, but I can't question the et. I think it'll be impossible for me to beat this time...it felt like the perfect pass. It doesn't mean I'm giving up though.
My goal is, and always has been, to run the quickest possible times bone stock. The most I may do to this car would be to add a Rotofab in the future, but for now, I'll try to improve on the stock times. Guys, I have no doubt my times will be beat. My car is fully optioned, and I'm a heavyweight myself. There is no doubt in my mind now that the new ZL1 will run 11.0s completely stock! Bet on it!
Old 05-22-2017, 06:46 AM   #38
newmoon
newmoon's Avatar
Drives: 2019 GT350
I have no problem with the 11:22, as a few others have gotten similar times, but this 130+mph makes me question the run. I remember when the 5th Gen ZL1 were all running 11:90s to 12:30s and he runs a 11:50s, alot of questions came up then as well.
Was the car 100% stock for this run, so no race fuel, no tuning, no cats removed, no weight reductions, or any other modifications? These days the meaning of "stock" seems to have very differant definitions to some.
2019 GT350 RR
2013 Boss Mustang
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 05-22-2017, 07:05 AM   #39
96MrBass
96MrBass's Avatar
Drives: GM
Dave said multiple times that he questions the mph also.
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
96MrBass is offline   Reply With Quote
Old 05-22-2017, 07:51 AM   #40
big dave
Drives: 2017 ZL1
There is no smoke and mirrors here. People can question whatever they want but it serves me no purpose to lie about what I ran. I have always loved the challenge of chasing the top guy on whatever list...but I would Never resort to cheating...period. I've never run race fuel, and the only weight reduction is removing half the junk from my trunk. Lol! I have a lot of experience racing over the years, and like CWebster, pay close attention to little things like optimum weather conditions, giving the car time to cool down, and being consistent when I find something that works. As I said before, I'm at a weight disadvantage to most, so I try to make up for it in learning how to drive what I race.
Old 05-22-2017, 07:58 AM   #41
big dave
Drives: 2017 ZL1
The funny thing is that I was doubting the 1/4 mph, I'm beginning to think I should be questioning the 1/8th instead. Others have run faster 1/8 mph but don't have the et. Is it possible my 1/8th should've shown much higher mph?
Old 05-22-2017, 08:34 AM   #42
762CAT
762CAT's Avatar
I don't question the MPH at all. A time slip is a time slip. Could there be error….sure. But I've seen weird stuff before and the mph seems high here…just trying to figure out why for fun not to question the OP. His time is great and his MPH is great. All good things.
17CamaroZL1 may be on to something. As he pointed out to get the cat to 60ft like that I am on a 305/45R18 Mickey Thomson ET Street R. That day it was at around 17.5 PSI so it would provide more rolling resistance on the big end and that may be the difference I was not accounting for. The Camaro gets a little wheel spin on launch and then has less rolling resistance as he progresses down the track.
As far as my run that day no noted loss of power with good DA and a very slight headwind of probably less than 3mph.
