Old 04-21-2017, 03:52 PM   #29
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
Originally Posted by Atomic Ed View Post
Go to post #36, page 3. You can see the control parameters for NLS for confirmation in the cut and paste from an HPtuners screen.
thanks... it does say pedal at 93%... ok,
what is VSS?
not much detail there though... too bad the manual doesn't explain it.
crazydmc is offline   Reply With Quote
Old 04-21-2017, 05:06 PM   #30
StateOfMind415
StateOfMind415's Avatar
Drives: 2016 Camaro 2SS NFG M6 MRC NPP
what is VSS?
VSS = Vehicle Speed Sensor
If VSS is over 31mph and gas pedal has been pressed more then 93%, it should activate. I believe it should work in any drive mode.
StateOfMind415 is offline   Reply With Quote
Old 04-21-2017, 05:08 PM   #31
crazydmc
ummmm
crazydmc's Avatar
Originally Posted by 2SS 1LE View Post
I just went out an played with NLS. I have my car in track mode 99% of the time and the last one percent is competition mode.
NLS seems slower to me because it bogs, I assume it is the traction controll kicking in.
yes, you will get major bog from first to second if Traction control is not turned off... the tires want to spin when you hit second, computer kicks in and cuts the power, your head lunges forward, and you feel like you messed up the shift.
I have an M6 and My motto is.... "spinning tires are either my INTENTION or my FAULT".. I don't want computer getting involved
Old 04-22-2017, 02:56 PM   #32
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
With all the questions surrounding no lift shift I finally broke down and looked in the owners manual. NLS only works in "competition mode" so you have you have a SS. the LT 4turbo or 6LGX does not. and competition mode is not sport mode. guess I have to upgrade.
dpevans is offline   Reply With Quote
Old 04-22-2017, 04:00 PM   #33
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
Finally some clarification, now I understand why last time when I was only in Sport mode the NLS didn't engage.
hzisfrom1994 is offline   Reply With Quote
Old 04-22-2017, 04:09 PM   #34
KyleL
Drives: Slow
It works in every mode all the time in mine. Based on my experience I'd have to agree with the throttle percentage comments.
2016 Toyota 4Runner
2017 Camaro ZL1
KyleL is offline   Reply With Quote
Old 04-22-2017, 04:44 PM   #35
JR91
Drives: Camaro 1SS
I was unable to find it in the manual. If you don't mind me asking, what page did you find it on?
JR91 is offline   Reply With Quote
Old 04-22-2017, 07:38 PM   #36
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
Originally Posted by Stryfe View Post
I was also very skeptical about NLS and didn't think it worked either.
However..........
It's not bouncing off the limiter like you guys think when you're using NLS.
Go drive your car in first gear and floor it to the limiter....it doesn't "bounce," it just kills the engine entirely.
If you were hitting the limiter while using NLS, your car would fall flat on it's face. Also, go try to use NLS and shift a little bit slower than normal...listen to the sound it makes....feel how smooth the shift is....if you did that while holding the gas pedal down on a car that does not have NLS, it would not go into the next gear smooth as butter. It would probably grind itself into the next gear.
However, I definitely don't think the NLS feature works before 6000 RPMs or so, despite what people say. If I stab the clutch at anything below 6000 RPMs, the RPMs definitely do jump up. But why would I ever NLS before then anyway?
Overall, it is a pretty cool feature. Smoked a Bentley Continental GT and Lexus ISF while using it the other day.
Should be able to smoke them without nls.
Marty McFlew is offline   Reply With Quote
Old 04-22-2017, 07:44 PM   #37
Marty McFlew
Where exactly n the manual does it mention NLS?
Old 04-23-2017, 08:22 AM   #38
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Despite it not being mentioned in the manual. I find NLS will still work in Sport mode but works BEST when you put it in Competition mode so that you don't introduce any bog.
If you are new to it and want to test it out. Try using it from 2nd to 3rd. It will be easier than 1st to 2nd. Just until you get the hang of it. Trust me it's the most unnatural feeling not lifting the throttle. Once you successfully get it down you'll love it and won't want to lift shift on WOT ever again.
When I first heard of it and tried it the first time. I didn't do something right and resulted in a pretty rough shift and I swore I would never use that again. However I'd find an on ramp or a stretch of open road and just give in to trying it again. About the 3rd or so try I finally got it and it is by far the absolute fastest way to shift this car. It almost sounds like the A8.. (I know not quite)..
Everytime he clutches you can hear and see the RPM's jumping to 6500.....
Dysan911 is offline   Reply With Quote
Old 04-23-2017, 01:05 PM   #39
JR91
Drives: Camaro 1SS
I agree with everything that you said. I tried it today and I messed up a few times, but when I got it right, it was pretty cool. The exhaust note does change when using it.
