Old 06-06-2017, 09:44 PM   #29
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Originally Posted by bub View Post
Definitely want to keep that stuff off the threads I assume, as it will throw your torque #'s way off....just stick to putting it on the flat mating surfaces.
Made that mistake once with some exhaust system studs. The anti-seize dramatically reduces assembly torque to get same bolt tension. Snapped off some exhaust hanger studs that way by accident by over-tightening with anti-seize on the threads. Basically graphite in a grease carrier paste.
Yep, Torque specs listed are for dry threads, if you apply anti seize you need to reduce torque by 15-20%.
thescreensavers is offline   Reply With Quote
Old 06-07-2017, 08:10 AM   #30
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Interesting. I've never heard of that before.
Old 06-12-2017, 05:48 PM   #31
thescreensavers
https://www.fastenal.com/en/83/torque-calculator
If you check lubricated bolts have lower torque specs(by 25%). It has to do with less friction on the threads. The torque wrench reads the resultant of everything the bolt touches which a lot has to do with this friction. So if you apply lubricant the resultant torque to achieve proper preload is reduced.
Old 06-13-2017, 07:34 AM   #32
Rocketman_1LE
Rocketman_1LE's Avatar
Drives: Nightfall Gray 1SS 1LE
Originally Posted by FNxR3DNECK View Post
Can't do it at my place, and I have dealer like 3 miles away so I'm just going to take it there.
Let me know FNxR3DNECK if you want to come by my place to do your car. I was going to clean mine this weekend. Just noticed the clicking noise this past weekend on my car, glad I came across this thread.
Rocketman_1LE is offline   Reply With Quote
Old 06-13-2017, 10:45 AM   #33
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
That sounds like a plan!!! I will text you!
IG: @NC_M1SS1LE
Old 06-13-2017, 08:35 PM   #34
Tulsa_SS
2017 1SS 1LE
Tulsa_SS's Avatar
Drives: 2017 1LE
I had a thumping noise that turned into a bad rattle. The strut is screwed up. Waiting for new strut to come in and fix the car.
Tulsa SS
2017 1LE
Tulsa_SS is offline   Reply With Quote
Old 06-13-2017, 10:15 PM   #35
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Update:
Coated the wheel mating surface with thin layer of anti size and torqued to 120 not 140. So far so good! Absolutely not noise, but I probably could've done even less anti seize, the excess has been slung from the hub to the inside barrel of the wheel. Nothing a wash can't fix but worth noting.
Old 06-14-2017, 04:19 PM   #36
Gville1LE
Drives: 2006 Lexus IS350
Update:
Because the components are susceptible to higher temps during your auto-xing, are you using a copper, ceramic, or nickel anti seize?
Gville1LE is offline   Reply With Quote
Old 06-15-2017, 08:07 AM   #37
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I didn't. Just standard anti seize. We'll see how it holds up at this weekends auto X. Got a 2 day event @ ZMAX.
Old 06-20-2017, 12:05 PM   #38
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
So far so good. The 2 day AutoX event went well and I didn't hear a single peep from the front besides screaming tires. LOL
Old 07-03-2017, 08:22 AM   #39
DenverTaco07
DenverTaco07's Avatar
ticking keeps coming back for me, even after torquing to 140 ft lbs. It will be fine for a couple days, a week or two etc. but keeps coming back.
Old 07-03-2017, 09:51 AM   #40
Mr. Meh
Drives: Sold
Dropped my ZL1 in to the local dealer this morning or lock turn clicking at med-low speeds.. I'm guessing mine will come out with the same response.
Also, it seems I have the NPP rattle on my passenger side tip as well -- not having that messed with until after my track day in August.
Mr. Meh is offline   Reply With Quote
Old 07-03-2017, 11:07 AM   #41
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
I had the ticking noise after picking my car up. Torqued to 140 ft lbs and it hasn't come back
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 07-03-2017, 09:21 PM   #42
1LEfireman
Drives: 2017 black on black 1LE
So I have the same clicking noise but only when I auto X. Did anyone mention that the clicking noise is the Ediff doing its thing? Makes sense to me. I never hear it driving around town. Thoughts???
1LEfireman is offline   Reply With Quote
