Old 04-04-2017, 10:52 AM   #29
Hagels316
Drives: 2016 Camaro 2SS A8
WRONG and WRONG
Originally Posted by TheRealJA105 View Post
So Stainless Works is just using the wrong terminology and Tim isn't WRONG as you tried to point out.
Hagels316 is offline   Reply With Quote
Old 04-04-2017, 10:56 AM   #30
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Guys grounding is NOT what the CCM is looking for. Plain and simple. Go rotate the actuator from its current position and remount on your dummy valve. It will set a CEL.
EFI Tuning is offline   Reply With Quote
Old 04-04-2017, 11:14 AM   #31
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
Originally Posted by Hagels316 View Post
WRONG- Grounding the valves DOES prevent a CEL. I upgraded to the Stainless works exhaust with AFM delete option (which provides AFM grounds in place of new valves). This is one of the many options you can select when purchasing a SW exhaust (either include AFM valves or delete them with included grounds).
The SW exhaust with AFM delete does not have AFM valves, but allows the factory AFM wiring to connect and be grounded to the exhaust via "dummy valves" thus fooling the car into thinking the valves are connected and working when they really are not. If you do not have a way to connect the AFM to something, it will throw a CEL. It's similar to the AFM delete module wiring that you can purchase.
If you don't believe what I am saying, call SW, they will explain it to you. My car is also proof that grounding does work.
Some of the catback exhausts do not include a grounding option for A8 cars, which forces you into purchasing a setup with new AFM valves making it more expensive. Or using the AFM delete harness from EFI as another option.
I should probably add that whether you have AFM grounds ("dummy valves") or not, you will still need to tune out AFM at the ECM level to prevent the engine from going into V4 mode.
Unless they changed something in the past few months I'm calling BULL SHIT.. I was one of first ones to do a AFM delete cat back from SW and had a CL from day one. They didn't have a clue as to why "plug them in and bolt them to the dummy mount" was all I got in response from them.
Maybe they have removed the butter fly and put a spring set up with tension on the "delete" mount.. that's the ONLY way it would work without getting a CEL
Perdieu is offline   Reply With Quote
Old 04-04-2017, 12:09 PM   #32
Hagels316
It's not bullshit. I have this setup on my car and it works just fine. I ordered my exhaust March of 2017. They must have changed something if you did not get the same result which would be rather lame on their part to not have it right the first time.
Old 04-04-2017, 12:16 PM   #33
Hagels316
Well, valve grounding works on my vehicle without setting off a CEL.
In any case, the EFI module that is offered is proven to work, but so does grounding.
Old 04-04-2017, 12:16 PM   #34
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
Sounds like they keep the motor but remove the valve/flap itself. The motor moves like it's being told to do, but physically there is no flap connected. So motor stays functional and plug in, moves its shaft, but doesnt do anything within the exhaust flow.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 04-04-2017, 12:25 PM   #35
Hagels316
This is probably the best explanation so far and upon visual inspection this is indeed what does occur (on my setup the motor movement is tuned out but still connected). SW calls it valve grounding.
But to Perdieu's point, this may have not been the case when this setup initially came out.
So we have 2 options:
1) Use the AFM module from EFI that is proven to work with no issues. This requires removal of the valve motors.
2) Keep the motors, but connect them to a grounded housing that has no physical moving flap but can still allow the motor to move (call this option whatever you like)
Old 04-04-2017, 12:26 PM   #36
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
It's not grounding, that is what everyone is saying. Just give up, the terminology used is wrong.
Old 04-04-2017, 12:36 PM   #37
Hagels316
Call it whatever you want, All I'm saying is it works on my vehicle and this is how the creator of that design explains it.
Old 04-04-2017, 12:38 PM   #38
TheRealJA105
Drives: 2013 C6Z06
No one ever said their setup didn't work
Old 04-04-2017, 12:49 PM   #39
EFI Tuning
EFI Tuning's Avatar
The actuator is already grounded via pin 1 of the connector. Pin 4 is 12V. Pin 2 is the PWM signal from the CCM. Pin 3 is the PWM feedback signal from the actuator. The CCM is looking for the correct frequency and duty cycle on the feedback signal.
Anyone that says it is because of being grounded is just flat out wrong and doesn't understand how it actually works. If you turn off AFM in the ECM and the actuators happen to be in the correct spot for AFM = off then you can certainly end up in a situation where you don't get a CEL. But don't imply it's because of "grounding". That is just false.
If you move the actuator from its commanded position you will set a CEL no matter what you do.
I'm an EE. I know what I'm talking about as it pertains to the workings of the AFM actuator. I had all of this on the scope when I did the PCB design.
Tim
Old 04-04-2017, 12:49 PM   #40
Perdieu
Perdieu's Avatar
I did
I fought the issue this past Oct for a couple weeks, Talked with Tim about it that's when he started the R&D..
Old 04-04-2017, 01:00 PM   #41
Hagels316
Tim
That's great.
Then why does SW call it grounding? What should this option be called? It makes sense to me that the creator of this "grounding" design would know what they are talking about. Just as you do as it pertains to your design.
Old 04-04-2017, 01:07 PM   #42
EFI Tuning
EFI Tuning's Avatar
Like I said... the notion of grounding has no merit here.
