#29 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
the dealer wont use the pinch welds, they are too close to the rocker panel. Most of the 4 post lifts use a pad system, those pads can reach and spread the load out correctly over the front subframe location just fine. |
#30 |
![]() Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
+1, far less stress on the frame when it's being lifted up on 4 points evenly. the dealer does need to use pads to properly clear the rockers. at least 2 members on here have had rockers replaced due to lift damage.
#31 |
![]() Drives: Not yet Join Date: Sep 2016
What are those 4 frame/subframe areas that they would use for the 4 points? I still have not seen any information on what those might be.
Thanks |
#32 |
![]() Drives: 17 krypton green 1le Join Date: Feb 2017
Found a previous thread with this post:
#33 |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
I never really felt comfortable using a standard jack stands (Y shape) with the metal ZL1 addons Lift points because:
I ended up getting these high quality ESCO 6,000lbs jack stands since it looks a lot sturdier than those other standard type jack stands I tried in the past, they're light and with the rubber pad on the top it's a great way to use the ZL1addons lift point and not worrying about breaking/damaging the rocker panels and possibility of the slippage (metal to metal vs metal to rubber).. See the below pictures for details: They also take much less space.. pay attention to that triangle shape feet and the welds I think I can confidently jack the car and not to worry about slipping anything.. Jacking with Mag pad with Mag Puck (ZL1addons) in the middle pinch weld opening then place the jack stands right under the Lift Points (also made by ZL1Addons) This is rear : (notice how the lift points sit on the rubber pad on the jack stands, they're completely covered and centered which makes it easier to jack on the opposite side to put all 4 lift points on the jackstands ) and front front from another angle now I can go to the other side since one side is on jack stands (rear and front lift points) and repeat the same steps to put all 4 of them on the jack stands Just for the added safety when I need to go under the car (for diff and tranny fluid change) I can use the second jack on the third/middle lift point but leave barely touching with the rubber jacking pucks (Amazon) so it wouldn't affect the balance of the other to but would be there for if all else fails For simple bleed job, pad/rotor change (or anything that doesn't require me to go under the car) I will simply leave it on the jack stands ![]() It's almost not touching Voila!
#35 | |
the body on both sides of the pinch weld is uneven, so there is a gap which is not addressed. it looks like it could cause the bolt on point to slip. |
#36 | |
I tried regular jack pucks but I still find the bolt-ons the best method at the moment for both lift and jack stand use . I re-tightened them after the first use as suggested.
#37 | |
#38 |
![]() Drives: 2016 Red Hot 2SS Join Date: May 2016
Since it's all vertical forces that's playing any role here when you put it on jackstand so should be fine.
#39 | |
#40 |
![]() Drives: 2017 Fifty 2SS Convertible Join Date: Aug 2016
Does anyone know the lift points for a 2017 SS Convertible? Seems the Generation 6 mag pad won't work with the convertible!
2017 2SS 50th anniv. vert.
2017 Jeep Laredo Altitude 2018 MB GLE350 |
#41 |
![]() Drives: 2018 2ss 1le Join Date: Jan 2018
so you can or can not jack the car from the diff...
i have 1le not sure if that makes a difference because of elsd |
#42 |
![]() ![]() Drives: 2015 BVM Camaro 1LE (2SS/RS) Join Date: Mar 2012
I bought 2 sets of ZL1 Addons jack pads (8 total) and installed 4 on the jack stand points and 2 more on the recommended factory floor jack points. All points are along the pinch welds and it worked out great.
I went to Harbor Freight and got their low profile racing jack made by Pittsburgh and 4 jack stand rubber pads to grip the ZL1 Addons jack pads. I would recommend the rubber pads to anyone using this ZL1 Addons product. https://www.harborfreight.com/rubber...-pc-63373.html I was anxious about lifting this car for the first time but the 6 jack pads is my #1 method now. The chassis of my 1le is so stiff I actually lifted both the front and back of the car at the floor jack point at the same time. Didn't have to touch the mount point near the rear diff. |
