#29 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
#30 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Except it's not normal in terms of industry-wide, just in terms of LT1/LT4.
#31 | |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
I discovered in my case that the perceived elapsed time is much longer than the actual elapsed time. My car on occasion sounded like it would crank forever before starting, but when I actually logged it the time never exceeded the GM specs (previously posted). (If I remember I'll post the log when I get home this evening.) |
#32 |
![]() Drives: 1967 Camaro, 2017 HBM ZL1 Join Date: Dec 2016
Guys, guys.....i think we can all agree that whatever the cause, the first start of the day is always the best and the loudest. It's music to my ears, and everyone else's at my complex.
#33 | |
Hot Dog
#34 |
![]() Drives: 2017 camaro ss Join Date: Jan 2017
This is a LT1 issue. It's normal. As others said it's direct injection and it gets worse when it's cold out. In my corvette manual it talks about this. Not sure if it's in the camaros manual or not.
#35 |
Bring It
Great thread! I came to post the exact same thing but paused to consider which section it belonged in hahah!
I have an M6 and mine takes maybe a second to second and a half longer than the video as well. Very comforting to know I'm not alone, as well as the cause that's been posted already. Nice! |
#36 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
Read on this forum to hold the power button with foot off the clutch until the accessories turn on and i hear a priming noise. Then push in the clutch, press start again and it cranks right up. I do this every time I cold start the car.
#37 |
![]() Drives: 2017 Summit White ZL1, M6 Join Date: Jan 2017
After a few times seeing mine cranking about 1-1.5 sec and reading the OM it states you don't have to hold the Engine start button the entire startup. Just press and let off it takes over. Thought I would mention this as I'm new to these type starting systems. Oil pressure is a big part of it I believe.
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396 |
#38 |
Bring It
If it's mechanical through something like the cam as posted above, this could not possibly have a benefit. It isn't electrically primed if I understood the above correctly.
#39 |
Here's a HP Tuners VCM scanner file with a little over a second crank time.
(It's from an LT4.) https://drive.google.com/open?id=0B0...DF2b2ZHVEdCMkk @ 14.9 seconds, rail pressure ~15 PSI, cranking starts @ 15.2 seconds, rail pressure ~33 PSI. @ 15.4 seconds, rail pressure ~61 PSI. @ 15.6 seconds, rail pressure ~103 PSI. @ 15.8 seconds, rail pressure ~323 PSI. @ 15.9 seconds, rail pressure ~538 PSI, first injector pulse @ ~16.0 seconds, the car starts I've logged this several times and it's the same sequence every time. The rail needs AT LEAST 500 PSI before the injectors will pulse. Once the injectors pulse the car starts pretty much immediately. Last edited by travislambert; 03-07-2017 at 07:52 PM. |
#40 |
Here's a nice little crank time chart.
This of course if the crank time... not the time from the press of the start button. Sometimes there's nearly a second (usually much less) that goes by while the low pressure pump pressurizes before the cranking starts. |
#41 |
(I have too many channels being logged to get a great refresh rate on this file as well as the previously posted file, so keep that in mind.)
Here's another log with a ~1.4 second crank time. https://drive.google.com/open?id=0B0...lUzNFFwWC1mdDg Trust me, 1.4 seconds seems like forever when you're listening to an engine crank. Many would call this 2-3 seconds by a subjective measurement. I'm guilty too. I was thinking it was taking 2-3 seconds before I starting logging it with a laptop. Last edited by travislambert; 03-07-2017 at 07:51 PM. |
#42 | |
Hot Dog
