Old 02-22-2017, 06:29 PM   #29
Jdelgado92
Jdelgado92's Avatar
Drives: '16 Red hot M6
Originally Posted by thundercrakcer View Post
This might sound silly, but what are j-pipes? or is it just a different name for x-pipes?
its an add on that looks like a j hençe the name lol it is used specifically to lessen the drone.
Follow me on Instagram
@julian_delgad0
Jdelgado92 is offline   Reply With Quote
Old 02-22-2017, 06:31 PM   #30
gdgraph
gdgraph's Avatar
Thread on J-Pipes:
http://www.camaro5.com/forums/showthread.php?t=102075
gdgraph is offline   Reply With Quote
Old 02-22-2017, 06:33 PM   #31
Jdelgado92
Jdelgado92's Avatar
Originally Posted by gdgraph View Post
No, they are not x pipes, they are a custom add on to try to knock down some of the drone, usually you cut into the stock pipe just before the muffler and put them in. I'll find the thread & picks on this...
beat me to it lol
@julian_delgad0
Old 02-22-2017, 06:41 PM   #32
gdgraph
gdgraph's Avatar
Haha, I saw your post right as I was copying the link to the thread and thought it was mine because you said it almost the same way haha.
Originally Posted by Jdelgado92 View Post
beat me to it lol
Old 02-22-2017, 07:00 PM   #33
megaphone
megaphone's Avatar
Drives: 2016 Camaro 2ss
And where we're you when I first started the thread
Good things come to good people. You sir are good people for taking the risk
megaphone is offline   Reply With Quote
Old 02-22-2017, 09:02 PM   #34
thundercrakcer
thundercrakcer's Avatar
Drives: Summit White 2SS, M6
Thanks for the info on this guys, however as I looked at that j-pipe thread all I can see happening is more back-pressure? Drone would probably be gone I'm guessing, but an x-pipe would do the same drone eliminating right?
thundercrakcer is offline   Reply With Quote
Old 02-23-2017, 07:58 AM   #35
gdgraph
gdgraph's Avatar
The J-pipe essentially works by creating an opposite resonance to the exhaust to try to cancel some of the drone out.
The x-pipe is unrelated to fixing drone, you can't really fix drone with an x-pipe. Our cars actually already come stock with an x-pipe already on them. One thing to note though is that the stock x-pipe is a cheaply made "stamped" x-pipe whereas most good quality aftermarket x-pipe are not stamped, which means they get better flow through them and therefore better performance.
Old 02-23-2017, 04:48 PM   #36
Jdelgado92
Jdelgado92's Avatar
What exactly do you mean by stamped
@julian_delgad0
Old 02-23-2017, 05:43 PM   #37
gdgraph
gdgraph's Avatar
I'm talking about the construction process. A cheap x-pipe like the one the stock exhaust has is not a "true x-pipe" like some of the better quality aftermarket exhausts have.
A stamped x-pipe is much easier to mass produce, and therefore cheaper, the issue with the construction of a stamped x-pipe is that they create a chamber for turbulence which means power loss.
A true x-pipe gives you better flow and better sound. Here's an example, the first pic is of the stamped x-pipe that GM used, and the second one is the true x-pipe that Borla uses (this is what I have on my car).
Old 02-23-2017, 08:54 PM   #38
Jdelgado92
Jdelgado92's Avatar
I see I see, thank you for the info. One more question for ya. If I wanted to go after market on xpipe, what would need to be done? For example get rid of the cats, a tune maybe? Idk too much about exhaust stuff lol
@julian_delgad0
Old 02-23-2017, 09:11 PM   #39
gdgraph
gdgraph's Avatar
You can pretty much get a mid-pipe set up (with a high flow x-pipe in the middle of it) from any of the main exhaust manufacturers and install it. I know for Borla you can do mid pipes with or without a secondary cat delete.
You should not need any tune for a cat-back system, if you do headers that's when you really need to do a tune.
If you get an axle back from flowmaster I would hit them up to find a mid-pipe that is compatible with their axle back (x-pipe is usually part of the mis-pipe assembly).
Old 02-24-2017, 07:01 AM   #40
Jdelgado92
Jdelgado92's Avatar
Awesome I more than likely will e adding and x-pipe in the future.
On other news....TODAY'S THE DAY MY DUDESSSSS and ladies
@julian_delgad0
Old 02-24-2017, 07:15 AM   #41
gdgraph
gdgraph's Avatar
Sweet! Can't wait to hear this set up, take lots of vids!!!
Old 02-24-2017, 08:36 AM   #42
PackersFan26
PackersFan26's Avatar
Drives: 2017 Summit White 2SS
Originally Posted by Techn9cian805 View Post
You're welcome to swing by and check mine out... just a short drive away
I may want to meet up and hear your system. Love the sound online of the Borla, would be great to hear it in person. The stock NPP is getting old
PackersFan26 is offline   Reply With Quote
