Old 02-02-2017, 12:01 PM   #29
oldman
Drives: SS 6 speed of course
so it looks like the a a large lip velocity stack on the filter side, meaning it ain't gonna pop thru the shield and should have a nice flow tip-in via stack.
Are there flow channels in the MAF like the factory setup?
Old 02-02-2017, 02:37 PM   #30
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
I'm not completely sure about that. I would need to take a look and see..
Blk16SS is offline   Reply With Quote
Old 02-02-2017, 02:40 PM   #31
Blk16SS
Blk16SS's Avatar
[QUOTE=KILLA BEE;9538068]
Originally Posted by Blk16SS View Post
I like that intake a lot, has the ECU adjusted more? do you still and here a difference. Im sure you do the reviews are GREAT
I think its a bit quicker based on my seat dyno. Tim will be tuning it in a few weeks so he may be able to elaborate a lot on it in regards to the maf sensor etc...
Old 02-03-2017, 10:06 PM   #32
ponchss
ponchss's Avatar
Drives: 2016 Camaro 2SS, 2006 corvette
Wow that looks great! It has nice fit and finish.
2016 Hyper Blue 2SS, A8, MRC, Ceramic white interior, NPP, Street Scene front splitter, 6LE side skirts, 20x10 and 20x11 Race star recluse wheels wrapped in MP4S.
ponchss is offline   Reply With Quote
Old 02-03-2017, 10:20 PM   #33
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
[QUOTE=Blk16SS;9538398]
I will be calibrating the MAF transfer function to eliminate any error. I'll update this thread once I've had a chance to see the data.
Tim
EFI Tuning is offline   Reply With Quote
Old 02-04-2017, 07:47 PM   #34
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
Hard to see on my phone but does this intake delete the factory sound tube?
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 02-04-2017, 08:00 PM   #35
Blk16SS
Blk16SS's Avatar
yes
Old 02-04-2017, 08:55 PM   #36
RideZX6R
RideZX6R's Avatar
Niiiice. Thanks
'12 E93 M3
'25 911 (ordered)
Formers...
Old 03-02-2017, 10:15 PM   #37
dbrcamaro
Drives: black 16 2ss camaro
I have this intake and a xpipe and I got my car tuned today. This intake is just as good as a rotofab tbo!
dbrcamaro is offline   Reply With Quote
Old 03-03-2017, 06:30 AM   #38
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
Originally Posted by travislambert View Post
Anytime you change the airflow characteristics around the mass airflow sensor the MAF calibration in the ECM must be adjusted to match if you want to engine to work properly.
Some people just like the added horsepower and don't care why it works. There's nothing wrong with that I suppose... to each his own.
If you care why, the short is, the MAF sensor is now miscalibrated and your engine is running leaner than before.
The MAF is now measuring less air than what's actually going into the engine (but it's probably flowing almost exactly the same as before). Now that the computer thinks there's less air, it's using less fuel. So less fuel with the same amount of air makes the car's AFR more lean than the factory intended.
Notice the jump in the charts you posted at around 4k RPMs. That's because the computer has fixed airflow models it blends with the MAF to estimate airflow. Because these models are unchanged, it helps offset the error with the MAF. However, above 4k the computer relies almost exclusively on the MAF. Since your MAF is now reading incorrectly, the AFR is now lean... and "leaner is meaner".
Over time the computer will use readings from the oxygen sensors to correct for the error of the MAF while running in closed loop... So most of the horsepower gain below 4k RPMs will eventually disappear.
The part that sucks is if you get the MAF tuned for the CAI, the horsepower is going to (mostly) disappear. You really will only benefit from a CAI if you need to flow a lot of air in a forced induction setup as the "cold" in the cold air intake isn't much of a factor anymore. The stock airbox does a pretty good job of getting fresh air.
And "CAÍ" is a misnomer, it's just an expensive alternative filter.
MAGAUSA is offline   Reply With Quote
Old 03-03-2017, 10:43 AM   #39
oldman
[QUOTE=EFI Tuning;9540992]
Tim
I think there would be a HUGE market for people that want to tweek the A/F but don't want to flash the ECU.
Old 03-03-2017, 10:45 AM   #40
oldman
STD dyno's are misleading at best.
Old 03-03-2017, 10:39 PM   #41
dbrcamaro
I can't agree or disagree with you since I don't have the baseline and afr's. but according to the "butt dyno too", it works pretty good.
Old 03-04-2017, 10:09 AM   #42
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
If you happy with it, thats your dyno your car your butt dyno then why give a S++++ what anyine else thinks. Go k$n , old school always does it thing.They havent been around A 100 years for nothing. And its the only intake thread that all the other newbies, dont jump in on and and try to market there product.
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
