Old 12-05-2016, 06:54 PM   #29
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
Originally Posted by Langhans2016 View Post
I ordered a driveshaft and axles from the drive shaft shop but still haven't got them! Did it take awhile to get yours? I also have the 15in wheel conversion kit coming from CarlyleRacing can't wait to get going again. That's crazy you broke yours while it's still stock. I couldn't get mine to hook well enough to break...I guess that time it did tho
I ordered the gforce axles and driveshaft the week before Thanksgiving and got them this past Thursday.
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 12-06-2016, 04:38 PM   #30
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
Originally Posted by Venom SS View Post
and pistons over 700whp
Check your reading skills brother! Says forged pistons
aka Reckless is offline   Reply With Quote
Old 12-06-2016, 04:42 PM   #31
Hard Parker
Hard Parker's Avatar
Drives: ZL1
:( oops lol
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 12-06-2016, 04:43 PM   #32
Hard Parker
Drives: ZL1
VR doing the work?
#savethemanuals
Old 12-06-2016, 09:30 PM   #33
aka Reckless
VR doing the work?
Yes sir!
Old 12-06-2016, 09:33 PM   #34
Hard Parker
Drives: ZL1
Hope to meet ya soon buddy...gonna do similar stuff
#savethemanuals
Old 12-07-2016, 06:54 PM   #35
Hard Parker
Drives: ZL1
What are the limits on the stock fuel system
#savethemanuals
Old 12-09-2016, 12:59 PM   #36
GirlyNFG
GirlyNFG's Avatar
91 or e85? Probably around 550-600 to be safe? I did my LT4 upper pump and injectors during the first part of the build, then lost rail pressure so added the cordes low side pump. Then was out of injector and added meth. sitting somewhere around 750-800 now depending on the dyno
PB: 9.569 @ 151.05
Old 12-09-2016, 03:05 PM   #37
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
At what HP did you lose rail pressure the 550-600 ??
At what HP did you lose injector 750-800 ??
How much meth are you spraying?
I'm trying to get all the info I can and make one post with all the fuel info I
can find LOL
Perdieu is offline   Reply With Quote
Old 12-09-2016, 04:23 PM   #38
GirlyNFG
GirlyNFG's Avatar
can find LOL
Yes, on rail pressure.
Injector was at like 720ish? It's all kinda a blur now. we pulled timing at like 5300 at that point until the meth was added.
Meth is the 'aggressive single nozzle' according to Alky Controls
These numbers were on a dynacom. Prior to the meth, I dyno'd on a mustang heartbreaker at 668. For comparison.
PB: 9.569 @ 151.05
Old 12-09-2016, 09:31 PM   #39
aka Reckless
When I heard the LT4 pump is like $850 I started thinking alky right away. And I was thinking E85 conversion, but it has some limitations from what I understand. You have to push a lot more E85 than gas to make power, so then the fuel system is still an issue. GDI is great, but sometimes I wish they stayed with the old fuel system on the LS cars :(
Still torn whether or not to bother with the LT4 pump and injectors when I can install alky for the same money and not worry about fueling really.
Old 12-09-2016, 09:41 PM   #40
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I always thought an axle or driveshaft was something that you don't need to replace unless you break the one in the car...like a clutch. Isn't there very little chance of a failure causing additional damage?
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 12-10-2016, 09:26 AM   #41
GirlyNFG
GirlyNFG's Avatar
Meth is a bandaid imo. I am debating turning down my hp and not needing it.
PB: 9.569 @ 151.05
Old 12-10-2016, 10:00 AM   #42
GirlyNFG
GirlyNFG's Avatar
I preferred to address things that were breaking on other cars. Stock camaros on drag tires are snapping axles. Driveshaft was mostly since there was a special if I bought it with the axles... lol. But, I have see a couple driveshaft failures and it is not pretty. It CAN hurt the car, potentially the driver.
PB: 9.569 @ 151.05
