#29 | |
![]() Drives: 2017 Corvette Stingray Grand Sport Join Date: May 2015
https://lmgtfy.com/?q=site%3Acorvett...om+A8+problems |
#30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Curious to see how the A10 functions and if has similiar issues.
#31 |
![]() Drives: Camaro ss Join Date: Nov 2016
#32 |
#33 |
![]() Drives: Ford Focus Join Date: May 2016
#34 |
Bump
#35 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
![]() Sport Mode Use where road conditions or personal preference demand a more controlled response. When selected, the Sport Mode indicator will display in the DIC. When in Sport Mode, the vehicle will shift automatically but hold a lower gear longer than it would in the normal driving mode based on braking, throttle input, and vehicle lateral acceleration. See Automatic Transmission 0 225. The steering will change to provide more precise control. If the vehicle has Magnetic Ride Control, the suspension will change to provide better cornering performance. If the vehicle is equipped with Active Exhaust, the exhaust valves will open earlier and more often.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
#36 |
Summit White 2SS
Drives: 2017 Summit White 2SS, 2018 Tahoe Join Date: Nov 2016
I was under the impression that the different drive modes also affected throttle response. Not sure of that could be part of the issue.
____________________ 2017 Summit White 2SS |
#37 |
Nah , just feels like I'm towing something , it does stay in 1st pretty long, I've started driving it in manual mode only cause I hate how the car shifts from 1 to 2 . Two dealerships say nothing is wrong but the ones I test drove don't feel like my car , they are very smooth and fast.
#38 | |
Track Mode Use when maximum vehicle exhaust valves will open.handling is desired. When selected, the Track Mode indicator will display in the DIC. When in Track Mode, the automatic transmission and steering will function similar to Sport Mode. The accelerator pedal is adjusted to give maximum control during the highest level of spirited driving. The Magnetic Ride Control will be set to the optimum level for vehicle responsiveness. If the vehicle is equipped with Active Exhaust, the
#39 | |
#40 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
I wonder if the car isnt auctually downshifting into 1st to start with.i know i my car if yousre in D it auctually starts you off in 2nd. Maybe its inly gou g into 2nd and the gear change your feeling is 2nd to 3rd. Go to the dealer ....ask for it to be looKed at a ask to test drive another car while you waut.
#41 |
![]() Drives: 2016 Hyper Blue 2SS A8 Join Date: Nov 2016
Sounds like you want a Mustang. They feel and look fast, but are really slow.
Look the car is fast whether you are in manual mode or not. Step on the gas a lug it alittle in manual mode and see how it compares. 8 speeds are not just good for ecconmy. You need to educate yourself a little more. You can switch quickly between auto an manual to check your gear and figure it out. There is no way you should be doing 25 in first unless you are pushing pretty hard. I just don't think you are giving useful info. Sorry. |
#42 | |
